Case 39 blu-ray
curtm275
Case 39 blu-ray
Post by curtm275 »
Get the following errors when ripping 'Case 39'
Saving 1 titles into directory /Users/***/Movies/Case_39
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '8796303360'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '8796567552'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '8796567552'
Failed to save title 0 to file /Users/***/Movies/Case_39/t00_Case_39.mkv
0 titles saved, 1 failed
crowfax
Re: Case 39 blu-ray
Post by crowfax »
Your drive is unable to read the disc with a high enough accuracy to obtain a 1:1 copy. There is no copy protection that can cause this. There are only two possible causes:
1. The disc is dirty, damaged or poorly manufactured.
2. Your drive is failing.
Number 1 is more likely, return the disc for a new one.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
curtm275
Re: Case 39 blu-ray
Post by curtm275 »
I hope its #1 since the drive is brand new!
Thanks for your help!
crowfax
Re: Case 39 blu-ray
Post by crowfax »
You're welcome.
Don't be surprised if you get a few discs that are all damaged. If the cause of the fault is a poor pressing then entire batches can be damaged. I had to return Sherlock Holmes about 5 times before I got one that read correctly.
Twowit2woo
Re: Case 39 blu-ray
Post by Twowit2woo »
crowfax wrote:Your drive is unable to read the disc with a high enough accuracy to obtain a 1:1 copy. There is no copy protection that can cause this. There are only two possible causes:
I bet the 'C' and 'V' keys on your keyboard are pretty worn :lol:
