First off, I apologize if I've created this post in the wrong sub-forum. Please feel free to move it to a more appropriate place if necessary.
I would like to change the way I use MakeMKV. I'd first like to do a full-disk backup, then use the full-disk backup to create an ISO file. Once the full-disk ISO file is created, I will then MOUNT the disk, and use MakeMKV to create the movie-only file I'll use for regular movie watching (with all the desired audio & sub-title options pre-selected), and archive the ISO file on my server. If I ever need special features, or alternate commentaries, I can always retrieve them from the ISO file - without having to re-rip the physical disk again.
Now, I tried to use "Image Burn" to create the ISO files. It does this successfully, BUT it removes my option to MOUNT the ISO file from my right-click menu. I'm using Windows 11. That's a FAIL.
I then installed the Windows OSCDIMG file, as part of their Assessment and Deployment Kit, but when I created the ISO file, the main movie file within the disk was made to be a fraction of its actual size. Absolutely a FAIL!
Can anyone suggest a software application I can use for this very specific task? I.e. :
1) It must make an accurate ISO file from a MakeMKV full-disk backup
2) It must still leave me with the option of MOUNTING an ISO file, if needed
I don't mind paying for software to do this task - it just needs to be able to meet the above 2 criteria.
I'm grateful for any suggestions!
Best software to create ISO file from full disk backup
Roscoe62
Re: Best software to create ISO file from full disk backup
I suggest you use Imgburn and you select just BDMV and CERTIFICATE to create the ISO. Instead of loading the ISO with Windows install the free VirtualcloneDrive from Elby and mount it with that program.Roscoe62 wrote: Tue Jun 24, 2025 10:23 pm Hi,
https://www.elby.ch/en/products/vcd.html
Roscoe62
I thought I should come back to this thread. I re-installed Image Burn, and also installed Virtual CloneDrive to handle mounting the ISO files as you suggested. It worked a treat!
Thanks for your suggestion - problem solved!
flojo
If you're going to mount it, use a .zip and not a .iso file and mount that. If you must have a drive letter you can mount the .zip with "subst". If it has to be a symlink I *think* you can use "mklink" prior to that. I can't test this, but as far as I know you could mount a NFS share with "mount", symlink it with mklink and associate a letter with subst, of course you should be able to do this without a symlink or using a NFS mount, so only "subst" could be used (if no driver letter is desired).
FWIW, many years ago on Windows 7 I had to use "mount" and "mklink" to get Adobe products to read from NFS network directories (SMB shares also worked for Adobe with mklink).
Rojma
Not sure where this is going wrong for you. I use this same exact process in Windows 11 and the ISOs created in ImgBurn mount just fine using native Windows 11 functionality and without having to install 3rd party software (Virtual CloneDrive). Have you just tried double-clicking on the ISO to see if it mounts instead of right-clicking?Roscoe62 wrote: Tue Jun 24, 2025 10:23 pm Now, I tried to use "Image Burn" to create the ISO files. It does this successfully, BUT it removes my option to MOUNT the ISO file from my right-click menu. I'm using Windows 11. That's a FAIL.
Rojma
Out of curiosity, I right clicked on an ISO in Windows 11 and confirmed that you don't initially get the Mount option. However, after right clicking the ISO if you select Show more options in the menu, then you get the Mount option. After right clicking the ISO did you select Show more options in the menu? Or more easily, you can just double click on the ISO to mount it. No need to right click on the ISO and select Mount to mount it.Rojma wrote: Sun Jul 20, 2025 6:14 pmNot sure where this is going wrong for you. I use this same exact process in Windows 11 and the ISOs created in ImgBurn mount just fine using native Windows 11 functionality and without having to install 3rd party software (Virtual CloneDrive). Have you just tried double-clicking on the ISO to see if it mounts instead of right-clicking?Roscoe62 wrote: Tue Jun 24, 2025 10:23 pm Now, I tried to use "Image Burn" to create the ISO files. It does this successfully, BUT it removes my option to MOUNT the ISO file from my right-click menu. I'm using Windows 11. That's a FAIL.
drxenos
If "Mount" isn't available in the context menu, it means .iso isn't associated with Windows File Explorer.Rojma wrote: Sun Jul 20, 2025 10:14 pm Out of curiosity, I right clicked on an ISO in Windows 11 and confirmed that you don't initially get the Mount option. However, after right clicking the ISO if you select Show more options in the menu, then you get the Mount option. After right clicking the ISO did you select Show more options in the menu? Or more easily, you can just double click on the ISO to mount it. No need to right click on the ISO and select Mount to mount it.
Rojma
Yes, that is true. However, Windows 11 has a "simplified" context menu that shows you a menu with minimal "most frequently used" options. If you want to see "all" of the options, you need select Show more options in the initial context menu. This will then show you the Mount option, confirming that .iso is associated with Windows Explorer.drxenos wrote: Mon Aug 11, 2025 1:41 pm
drxenos
You can change it to always show you the full menu.Rojma wrote: Mon Aug 11, 2025 4:31 pmYes, that is true. However, Windows 11 has a "simplified" context menu that shows you a menu with minimal "most frequently used" options. If you want to see "all" of the options, you need select Show more options in the initial context menu. This will then show you the Mount option, confirming that .iso is associated with Windows Explorer.drxenos wrote: Mon Aug 11, 2025 1:41 pm
Rojma
Yes that is also true, but there's nothing in the Windows GUI that exposes that option. You have to either modify the registry or use a 3rd party utility to get that option. This is something that most people will not have done.
The whole point of my original reply was explaining a reason why the original poster possibly didn't see the Mount option, and not the semantics of the right-click context menu. I am guessing that the original poster just didn't select Show more options so that he could see the Mount option, or he didn't just double click on the ISO file to mount it. We won't know until he replies.
