BD-RE BU40N Issue
phileeny
BD-RE BU40N Issue
Post by phileeny »
Product: BD-RE BU40N
Revision: 1.03
Serial number: MO6L66B5903
Highest AACS version: 82
Firmware version: 1.03
Can someone give me some info or help on an issue I'm having with this drive.
It is connected internally to the motherboard on a self built windows 11 PC, new parts last year.
It works perfectly fine and reads any disc I put in it, and then It will decide to not see any disc at all, my other drive the BH16NS55 also connected internally has never had this issue, If I remove the driver and restart the PC it works for a while, then not.
Any ideas?
Unraid media server (self confessed data hoarder)
Zidoo x9 player Updated to Dune HD Pro One 8K Plus
65" TV and 9:1 sound system
Re: BD-RE BU40N Issue
phileeny wrote:
Mon Aug 11, 2025 7:02 am
Revision: 1.03
Any ideas?
Sometimes LG drives can get themselves a little confused. This is when they won't read any discs. Just turn of power to the drive for a minute or so before powering it back up. If the drive is connected internally, shut down the PC for a couple of minutes and the drive should reset itself.
phileeny
Post by phileeny »
interesting, I have been looking to convert it to external USB, or get a new external one
WaDe43
Post by WaDe43 »
OS device name: F:
Revision: 1.03
Serial number: XXXXXXXXXXX
I'm having this same issue. I flashed the drive and it was working fine for a few weeks but now seems to struggle. I've tried disconnecting it from the power for an extended period of time but it only seems to intermittently fix the issue for a couple of discs and then stops reading them again. Is there anything else you could suggest that may provide a longer term fix for this issue?
