Pioneer BDR-209 firmware version 1.20 id61
Chapman
Hi.can the above blue ray drive be flashed to read uhd any help please.?
Re: Hl-dt-bd-re bu40n ver 1.05
Yes it needs to be flashed to enable libredrive and 4K readability. Flash it with BU40N 1.03-MK firmware.Chapman wrote: Sun Aug 10, 2025 6:39 pm Hi any please.just purchased verbatim external writer .not read 4k discs or write .do need reflash.is current version software .not good .it is libredrive. If so which old file would I choose any help many thanks. Mark
Chapman
Hi ,from novice flashing verbatim 4888 slim writer.from bd,re, Bu ,mt 1959 libredrive possible not enabled.Installed & flashed bu40n 1.03 bin file with martys,and gui flash tool 1.36 . Should this drive work for uhd blue ray .mkv maker , still not decrypting or recognise ing ,disc just spinning with blue light on. Any help please. Banging my head again st brick wall..thanks again.
Post your Makemkv info.Chapman wrote: Tue Aug 12, 2025 7:59 am Hi ,from novice flashing verbatim 4888 slim writer.from bd,re, Bu ,mt 1959 libredrive possible not enabled.Installed & flashed bu40n 1.03 bin file with martys,and gui flash tool 1.36 . Should this drive work for uhd blue ray .mkv maker , still not decrypting or recognise ing ,disc just spinning with blue light on. Any help please. Banging my head again st brick wall..thanks again.
Chapman
Mkv info ?? Markright flash
Chapman
Hi ,from novice flashing verbatim 4888 slim writer.from bd,re, Bu ,mt 1959 libredrive possible not enabled.Installed & flashed bu40n 1.03 bin file with martys,and gui flash tool 1.36 . Should this drive work for uhd blue ray .mkv maker , still not decrypting or recognise ing ,disc just spinning with blue light on. Any help please. Keep coming at scsi error. Any help please
