Midway (2019) 4k backup problem
Negatron
Post by Negatron » Sun Aug 10, 2025 2:12 pm
I have been converting my blurays all to backup versions with makemkv, and I recently found a movie that will not play properly as a backup. When I make the backup...everything goes fine, but it will not access the menu, and if the menu is bypassed is starts from a tropical scene intead of the winter scene. i have tried making a mkv and it works fine. has anyone had this problem or know what the cause is?
Re: Midway (2019) 4k backup problem
Post by dcoke22 » Sun Aug 10, 2025 2:20 pm
You said you made a .mkv file and it worked fine. And you said the backup process finished successfully. That suggests the problem is with the player.
Negatron
Post by Negatron » Sun Aug 10, 2025 2:22 pm
Thank you, i just ordered a LGWH16N40 from Amazon. I then will either get someone to change the firmware or I have heard DVDFAB has software that will do it for you. I hope it works... On amazon there was person that said it did work for this drive...I hope they are right.
If anyone has any info on changing the firmware with DVDFab or other ways...please speak up.
Post by dcoke22 » Sun Aug 10, 2025 6:02 pm
I was just reminded that Midway has screen pass protection. That's probably what's causing trouble for your player.
Midway 2019 4K (new BD-J protection?)
Post by dcoke22 » Sun Aug 10, 2025 6:05 pm
There's a maintained and dedicated post on this forum showing you how to change the firmware on a drive yourself.
Ultimate UHD Drives Flashing Guide
That post has the instructions and links to all the tools and firmware you'll need. If you're on Windows, there's even a GUI to assist in flashing the firmware.
Negatron
Post by Negatron » Sun Aug 10, 2025 11:35 pm
Thank you very much for the info!
