Pioneer BDR-209 firmware version 1.20 id61
Chapman
#1 Post by Chapman » Sun Aug 10, 2025 6:39 pm
Hi.can the above blue ray drive be flashed to read uhd any help please.? :D
Re: Hl-dt-bd-re bu40n ver 1.05
#2 Post by MartyMcNuts » Mon Aug 11, 2025 2:40 am
Chapman wrote: Sun Aug 10, 2025 6:39 pm Hi any please.just purchased verbatim external writer .not read 4k discs or write .do need reflash.is current version software .not good .it is libredrive. If so which old file would I choose any help many thanks. Mark
Yes it needs to be flashed to enable libredrive and 4K readability. Flash it with BU40N 1.03-MK firmware.
Chapman
#3 Post by Chapman » Tue Aug 12, 2025 7:59 am
Hi ,from novice flashing verbatim 4888 slim writer.from bd,re, Bu ,mt 1959 libredrive possible not enabled.Installed & flashed bu40n 1.03 bin file with martys,and gui flash tool 1.36 . Should this drive work for uhd blue ray .mkv maker , still not decrypting or recognise ing ,disc just spinning with blue light on. Any help please. Banging my head again st brick wall..thanks again.
#4 Post by Coopervid » Tue Aug 12, 2025 9:40 am
Chapman wrote: Tue Aug 12, 2025 7:59 am Hi ,from novice flashing verbatim 4888 slim writer.from bd,re, Bu ,mt 1959 libredrive possible not enabled.Installed & flashed bu40n 1.03 bin file with martys,and gui flash tool 1.36 . Should this drive work for uhd blue ray .mkv maker , still not decrypting or recognise ing ,disc just spinning with blue light on. Any help please. Banging my head again st brick wall..thanks again.
Post your Makemkv info.
Chapman
#5 Post by Chapman » Tue Aug 12, 2025 4:27 pm
Mkv info ?? Markright flash
Chapman
#6 Post by Chapman » Wed Aug 13, 2025 4:55 am
Hi ,from novice flashing verbatim 4888 slim writer.from bd,re, Bu ,mt 1959 libredrive possible not enabled.Installed & flashed bu40n 1.03 bin file with martys,and gui flash tool 1.36 . Should this drive work for uhd blue ray .mkv maker , still not decrypting or recognise ing ,disc just spinning with blue light on. Any help please. Keep coming at scsi error. Any help please 🙏?
