deadchip12
@RESET_9999
Usually, with the full uhd bluray disc (bdmv folder), I just find the main playlist with BDInfo, put it in mkvtoolnix and convert it to mkv to watch the movie on the ugoos, but now if I want to watch Special Features/Bonus Contents as well, what should I do?
I dont know...
But FYI, mkvtoolnix can find the correct playlist by itself, no need for bdinfo.
deadchip12
oh cool thanks for letting me know.RESET_9999 wrote: ↑Sun Jul 13, 2025 3:25 amI dont know...
Btw do you have the cmv4.0 rpu for Dune Prophecy? Can't find P5 version anywhere to do the transfer, only P8.
p5 or p8 doesnt matter. they have the same metadata
deadchip12
Do these plots look normal (it's Dune Prophecy)? :
bluray's madvr plot:
web's madvr plot:
web's DoVi plot:
What is the point of generating DoVi plot if it always looks different from the other two?
The colorist can choose a tuning parameter that controls the aggressiveness of Dolby Vision tone mapping. Lower values result in less tone mapping and a brighter image, while higher values apply more aggressive tone mapping, resulting in a darker image.
https://slow.pics/c/OA0pupEN
You've uploaded the web dovi plot twice.deadchip12 wrote: ↑Tue Jul 15, 2025 2:33 amDo these plots look normal (it's Dune Prophecy)? :
web's madvr plot:
web's DoVi plot:
If you are wondering why the madvr plot looks different to the Dovi plot, it's because DV (& HDR10+) metadata are meant to be used during playback for tone mapping. They don't always represent the actual brightness (1:1) of the shots. madmeasureHDR.exe will always be more representative of the actual brightness.
deadchip12
Yeah my bad. That was supposed to be the web's hdr10 madvr plot, which looked similar to the bluray's one, meaning the transfer can be done.coopzr wrote: ↑Tue Jul 15, 2025 9:45 pmYou've uploaded the web dovi plot twice.deadchip12 wrote: ↑Tue Jul 15, 2025 2:33 amDo these plots look normal (it's Dune Prophecy)? :
web's madvr plot:
web's DoVi plot:
I just wondered why we needed to generate the dovi plot here if they would look different to the madvr plot anyway.
Reset which workflow to use for the making mp4 5 profile dolby vision from mkv 5 profile dolby vision ?RESET_9999 wrote: ↑Fri Jul 11, 2025 10:28 pmYour video is missing the framerate at the bitstream level. You can fix it in 9-2
This used to be the case with all the Apple WEB-DL, but now, all the reputable groups fix it.
ragico wrote: ↑Fri Jul 11, 2025 10:15 pmHi RESET_9999 ,
Karate Kid Legends has got both DV8 and HDR10+
I want to remove HDR10+ and use your scripts workflow 2-2
Everyhting was done and the resulting file is "Karate Kid Legends_HDR10plus_removed". But why his framerate is 25.000 fps whilst the original movie is 23.976 fps?
mp4 version workflow 5
afsajahanara
Dolby Vision can now be included in MP4 files using MP4 Muxing. This advancement allows for high dynamic range (HDR) video content to be distributed more easily while maintaining compatibility and superior visual quality across supported devices and platforms.
deadchip12
@RESET9999
May I ask what HYBRID in the title actually means? I thought it meant this version already included DV cmv 4.0 from the web version but upon checking with dovi scripts it does not.
The.Accountant.2.2025.UHD.BluRay.2160p.TrueHD.Atmos.7.1.DV.HDR10P.HEVC.HYBRID.REMUX-FraMeSToR.mkv
uhdiznotenough4mee
In this example HDR10+ was injected from WEB-DL to UHD Blu-ray remux, which includes DoVi as retail.deadchip12 wrote: ↑Wed Aug 06, 2025 11:39 pm@RESET9999
deadchip12
Thanks. Wonder why they didn't transfer cmv 4.0 from WEB-DL as well...uhdiznotenough4mee wrote: ↑Wed Aug 06, 2025 11:43 pmIn this example HDR10+ was injected from WEB-DL to UHD Blu-ray remux, which includes DoVi as retail.deadchip12 wrote: ↑Wed Aug 06, 2025 11:39 pm@RESET9999
why are some movies 4000nits MDL on the disc? and other ones 1000nits? what are the differences?
