Need Help with arrow the good the bad and the ugly
Mets720
#1 Post by Mets720 » Sun Aug 10, 2025 1:28 pm
Im trying to do Arrow The Good, The Bad and The Ugly and i have updated the Keydb files and still running into " The volume key is unknown for this disc" unless i downloaded the wrong keydb file or installed it wrong. if anyone can guide me in the right direction that would be helpful.
Re: Need Help with arrow the good the bad and the ugly
#2 Post by dcoke22 » Sun Aug 10, 2025 3:00 pm
Can you copy and paste your MakeMKV log into a post here on the forum? Are you getting a "HK download failed or is disabled" message?
Instructions on how to setup the keydb.cfg with MakeMKV: https://forum.makemkv.com/forum/viewtopic.php?p=162444#p162444
Mets720
#3 Post by Mets720 » Sun Aug 10, 2025 3:32 pm
this is what showing up on the log
Saved AACD dump file as
The Volume Key is unkown for this disc - video can't be decrypted
I followed the instruction for a mac and nothing really is updating i don't know since Mike hasn't comeback to the site or i'm installing the keydb files wrong
Carpet
#4 Post by Carpet » Sun Aug 10, 2025 4:57 pm
Both the Theatrical and Extended Cut discs are ripping for me (on a Windows PC). Are you using the latest keydb.cfg version (2025-08-10 18:27:40) and have you restarted MakeMKV after copying the file? This post says ~/Library/MakeMKV might be the location for a Mac?
