Can't Buy a License
mbuck
Can't Buy a License
Post by mbuck » Sun Aug 10, 2025 2:23 am
As of 8/9/25, the beta key is broken. It says that the latest version is too old and won't run. I am willing to purchase a permanent license key, but I can't. The link takes me to the PayPro Global site and it gives an error: 'The action is temporarily unavailable' Doing a search on the PayPro Global web site for MakeMKV or even just MKV, it yields no search results. Suggestions???
Re: Can't Buy a License
Post by Woodstock » Sun Aug 10, 2025 2:27 am
As of when you posted your message, there were over two dozen "can't run because of license message threads active on the forum. Do you think yours will fix the often-reported issue?
mbuck
Post by mbuck » Sun Aug 10, 2025 3:53 am
Do you think it is helpful scolding me for a message when that wasn't the point of my message. Maybe you didn't completely read my message. Or maybe you didn't read the subject of my message.
wallyopd
Post by wallyopd » Sun Aug 10, 2025 1:32 pm
On the front page of the board alone there are threads titled:
How to buy?
Purchased License
Unable to purchase MakeMKV
Beta Key not updated and PayPro down
Trying to purchase but getting "The action is temporarily unavailable"
Payment site down?
Unable to purchase MakeMKV license
The first thing I usually do before posting on a forum for help is to look and see if others are having similar issues, which clearly is the case. There is no additional information to provide that isn't in one of the many other threads on the subject.
Post by dcoke22 » Sun Aug 10, 2025 1:41 pm
mbuck wrote: Sun Aug 10, 2025 3:53 am Do you think it is helpful scolding me for a message when that wasn't the point of my message. Maybe you didn't completely read my message. Or maybe you didn't read the subject of my message.
It has been a frustrating 10 days on this forum and folks are getting a little cranky. :)
You're correct, the ability to purchase MakeMKV is currently broken. It seems PayPro Global ran out of a stock of permanent keys to hand out when someone buys MakeMKV. This was unexpected. The beta key is also expired. The program's author, Mike, has not made a public statement or anything that I'm aware of. That just leaves us with a lot of speculation.
In my view, this is just an unfortunate confluence of events. Hopefully soon it'll all get sorted out. In the meantime we all need a little patience and grace. :) If you want to use MakeMKV but don't have a permanent key, you'll have to look around the forum for instructions on how to set your computer's clock back in time.
vhslover
Post by vhslover » Sun Aug 10, 2025 3:59 pm
It 10000000% is helpful.
Because you apparently just don't know how to read.
Regardless of what your title says - literally every other recent post (from people who apparently also lack the ability to read) is asking/complaining/repeating the same exact thing.
  • The beta key being expired
  • Buying a license but not receiving it
  • Being unable to buy a license
  • Mike being awol
  • Not being able to use a program some guy has spent who knows how long building probably by himself while offering a ability to use in a free-ish capacity to everyone else
The answer has been the same every single time.
You can trick the software by changing the system time on your machine, including suggestions depending on what platform you are using.
No, we don't know when he'll be back.
The best we can do is simply wait for him to come back and hope whatever reason for his absence isn't something too serious because he's a human too.
Get it?
Got it?
Good. Jesus Christ, Harambe help us all.
Blyth
Post by Blyth » Sun Aug 10, 2025 4:59 pm
Got to say I read it properly the first time and guess what... It's no different from the rest of the posts that are already up.
Normally you join a forum search for the problem and if you couldn't find any new post then you ask for help, with this particular problem there isn't any need to search as it's always being talked about.
