sure email me that drive info section see below for emailUHDforLIFE wrote: Sun Aug 10, 2025 1:41 am Hi, I have a BDR 212V and I would like a flash.
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number:
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
thanks!
Pioneer BDR-212DBK vs BDR-212V
Re: Pioneer BDR-212DBK vs BDR-212V
I purchased a Pioneer device on eBay.
I have no idea how to check whether the burner is new or used (any ideas?), but at the moment it seems to be working, even though I haven't made any ripping yet.
However, I would like to ask you this.
Here is the information returned by MakeMKV:
OS device name: I:
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: XXXXXXXXXXXXX
Firmware date: 2019-01-10
Highest AACS version: 78
Drive platform: RS8F00
Firmware version: 1.00/ID61
The unit arrived with the initial firmware, and it seems to be already unlocked as a LibreDrive device.
However, I understand that the firmware may be too old and unable to rip discs with recent AACS versions.
Do you suggest I update the firmware or leave it as it is?
What limitations would I have if I leave the current firmware?
Thank you for your attention!
OS device name: I:
Revision: 1.00
The drive is fairly old but it should be OK. I will send you a PM that allows also ripping of UHD discs. Regarding the newest AACS dumps have to be sent from a non-Pioneer drive but you can always use the keydb.cgf file. Read this thread:carpler wrote: Mon Aug 11, 2025 11:12 am I purchased a Pioneer device on eBay.
OS device name: I:
Revision: 1.00
viewtopic.php?f=12&t=38293
NathanielHornblower
Hello again,
The two drives I ordered arrived. Unboxed one and put in the OWC case (Thanks for the rec, Billy!) and here's the info:
Revision: 1.02
Serial number:
Firmware version: ID06-
no problem just email that over to me for the flasher see belowNathanielHornblower wrote: Thu Aug 21, 2025 3:43 am Hello again,
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: Firmware date: 2022-05-31 Bus encryption flags: 13 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
Hello, if someone can PM me with what I need for my BDR-212V thank you
Revision: 1.02
Serial number: DGDL028112WL
Firmware version: ID06Re: Pioneer BDR-212DBK vs BDR-212V
PM sent.ihavoc wrote: Tue Aug 26, 2025 2:15 pm Hello, if someone can PM me with what I need for my BDR-212V thank you
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: DGDL028112WL Firmware date: 2022-05-31 Bus encryption flags: 13 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
FWIW, I just successfully ripped all 30 UHD discs of the "Game Of Thrones: The Complete Collection" UHD box set using a Pioneer BDR-212V in a OWC Mercury Pro (OWCMR3UKIT) enclosure.
This is frivolous information to most, but it's a landmark for me as I never thought disc GOTUHD_S7_D2_B5 would rip :-/
It's amazing how much better Pioneer drives are!!flojo wrote: Thu Aug 28, 2025 10:52 pm FWIW, I just successfully ripped all 30 UHD discs of the "Game Of Thrones: The Complete Collection" UHD box set using a Pioneer BDR-212V in a OWC Mercury Pro (OWCMR3UKIT) enclosure.
i know but so many dont believe us and think we are shillsMartyMcNuts wrote: Thu Aug 28, 2025 11:45 pmIt's amazing how much better Pioneer drives are!!flojo wrote: Thu Aug 28, 2025 10:52 pm FWIW, I just successfully ripped all 30 UHD discs of the "Game Of Thrones: The Complete Collection" UHD box set using a Pioneer BDR-212V in a OWC Mercury Pro (OWCMR3UKIT) enclosure.
Yep, we say these things just for shits and giggles!Billycar11 wrote: Fri Aug 29, 2025 1:03 ami know but so many dont believe us and think we are shillsMartyMcNuts wrote: Thu Aug 28, 2025 11:45 pmIt's amazing how much better Pioneer drives are!!flojo wrote: Thu Aug 28, 2025 10:52 pm FWIW, I just successfully ripped all 30 UHD discs of the "Game Of Thrones: The Complete Collection" UHD box set using a Pioneer BDR-212V in a OWC Mercury Pro (OWCMR3UKIT) enclosure.
Hi, sorry for replying to an old post, but could you advice me where I can download LG WH16NS58 1.V5 and VPTools? I just purchased BUFFALO BRXL-16U3 and am trying to make it a BD quality scanner. Thank you in advance.Coopervid wrote: Mon Dec 16, 2024 10:29 pm And yes we checked that wit LG WH16NS58 1.V5 and VPTools. All newer multilayer discs after Verbatim moved the equipment to Taiwan have issues at the layer break. 50 Gb Ritek are still Ok. Were. These tests are 2 years old. Advice: Stop burning discs!
I replied to your PM. Is this Buffalo a full size drive with the MT1959 chip? The safest way to check is posting or sending your Makemkv info.macep wrote: Sat May 16, 2026 12:40 amHi, sorry for replying to an old post, but could you advice me where I can download LG WH16NS58 1.V5 and VPTools? I just purchased BUFFALO BRXL-16U3 and am trying to make it a BD quality scanner. Thank you in advance.Coopervid wrote: Mon Dec 16, 2024 10:29 pm And yes we checked that wit LG WH16NS58 1.V5 and VPTools. All newer multilayer discs after Verbatim moved the equipment to Taiwan have issues at the layer break. 50 Gb Ritek are still Ok. Were. These tests are 2 years old. Advice: Stop burning discs!
