NEW Single Drive Flasher - available worldwide!!
Re: UHD Enabled Drives (Australia, NZ & Singapore among others!) & DIY "Single Drive Flasher UI" available worldwide!!
Stock levels updated in first post.
tymon
Post by tymon »
Do the "ready to go!" players support discs from all regions? We've got discs from multiple regions and would like to start ripping them to a media server so we're looking for a player that can handle all of those regions as well as newer 4k discs.
tymon wrote: Mon Aug 04, 2025 2:36 am Do the "ready to go!" players support discs from all regions? We've got discs from multiple regions and would like to start ripping them to a media server so we're looking for a player that can handle all of those regions as well as newer 4k discs.
It's not the drive but the ripping software used that removes/ignores any region coding. MakeMKV doesn't care what region a disc is from and rips them anyway. I have many BD discs from all over the world, region A, B, C and have never had an issue ripping any of them with MakeMKV.
Just FYI, 4K UHD discs are region free.
cqecho
Post by cqecho »
Hi Marty,
Does this Pioneer BDR-S13C-X model can support UHD ripping, because your store is BDR-S13J-X that can't be found in the market, if I got this Pioneer BDR-S13C-X does this mocel can be flashed to support UHD rip, if yes, can you support I can pay you.
Thank!
cqecho wrote: Sat Aug 23, 2025 1:24 pm Hi Marty,
Thank!
I don't want to make assumptions as I have never seen one of those before. I certainly don't recommend that Chinese version either.
