How long to get key
Re: How long to get key
Post by dcoke22 » Sat Aug 09, 2025 2:02 pm
Keiyuu wrote:
Sat Aug 09, 2025 12:20 pm
mlm123 wrote:
Fri Aug 08, 2025 10:00 pm
Riesz wrote:
Fri Aug 08, 2025 2:47 pm
Here's what I did. Make a new text file and paste this into it, changing to your makemkv directory.
@echo off
if not "%1"=="am_admin" (powershell start -verb runas '%0' am_admin & exit /b)
date 05-04-25
time 00:00:00
start /wait "test" "D:\Program Files (x86)\MakeMKV\makemkv.exe"
w32tm /resync
Save as something like makemkv-date-change.bat
".exe," ".bat"? Did you look to see which forum you're in?
What are you confused about? It's a simple script to automate the process every time you launch MakeMKV, and then automatically sync it to the correct time.
That is a 'simple' Windows script posted in the MacOS corner of the forum.
keithmock
Post by keithmock » Sat Aug 09, 2025 3:11 pm
Sorry, Newb here. I am confused. I have to buy a license Key to do the trial version? :?:
Post by dcoke22 » Sat Aug 09, 2025 3:23 pm
No.
Normally there is a beta key available that unlocks full functionality. It expires every couple of months and the program's author often waits a few days before a new key is posted to encourage folks to buy a permanent key.
A little more than a week ago there was a problem with the system for purchasing a permanent key. It unfortunately coincided with the expiration of the most recent beta key. Since then, we've been waiting for the program's author to get things sorted out. At the moment there's no current beta key nor a way to purchase a permanent key.
Blyth
Post by Blyth » Sat Aug 09, 2025 3:26 pm
Change the computer clock back a month to July
Cope and Paste the Beta Key viewtopic.php?f=5&t=1053
And then you are good to go :D
