Can't find a USB Buffalo External BR Reader/Burner
djfnec2005
Post by djfnec2005 »
I have installed the MakeMKV program but it can't find my usb bluray drive. Any thoughts on what I can do to get it to detect? It's a USB Buffalo external player. I can rip the files to my hard drive with anydvd and then convert them with Make MKV but I can't rip them right to MKV. Any help would be appreciated. Thanks
Re: Can't find a USB Buffalo External BR Reader/Burner
Post by mike admin »
can you please enable "log debug messages" in preferences, restart the program and post the log here? This will help to troubleshoot the problem.
djfnec2005
This is without the drive plugged in. If you need it with the drive plugged in and turned on let me know.
MakeMKV v1.4.8 beta win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Dave/MakeMKV_log.txt
FAILURE: Code 3221225488 at `O>x,Je3*7/w%s:213130927
FAILURE: Code 3221225488 at dSxz^+8VEkv' -.':121263061
FAILURE: Code 0 at dSxz^+8VEkv' -.':121262762
FAILURE: Code 0 at 4sa,n4KrKusRVFPXBpq1+:2CTF:29393516
The program can't find any usable optical drives.
yes please, also try it with the drive. Also, what OS are you using?
djfnec2005
No Problem, I will post the new log data with the drive plugged in and turned on when I get home tonight. The OS is Windows Vista Home Premium 64 bit on a HP Pavilion dv7-1285dx laptop, 2.4GHz Intel Core 2 Duo P8600, 6GB 800MHz DDR2, Mobile Intel PM45 Express Chipset, USB 2.0. Let me know what other info you might need.
djfnec2005
Here is the log data with the drive plugged in and turned on
djfnec2005
Has anyone used an external usb drive successfully with this software? I'm thinking of possibly getting a different drive to attach to my laptop.
