Automatic KH downloading is disabled or failed
makemg123
Post by makemg123 » Fri Aug 01, 2025 2:57 pm
Hi, I've used MakeMKV before, but haven't been at it for a few months.
Coming back to it now, and I'm getting the error:
Using LibreDrive mode
Downloading latest HK to ...
Saved AACS dump file as
I've checked, and have enable internet access on
I don't think i'm on geoblock, have tried direct via ISP and VPN
I'm looking at the FindVUK online database for manual sync, but wondering if anyone else has this error and if so, any recommendations?
I have version 1.18.1, and full registered recently as well.
Thanks in advance
Re: Automatic KH downloading is disabled or failed
Post by dcoke22 » Fri Aug 01, 2025 3:48 pm
With your VPN, try different exit nodes until you find a location that works.
VA1DER
Post by VA1DER » Thu Aug 07, 2025 6:50 pm
I've started running into this too. With seemingly innocuous VPN endpoints.
Why are some VPN endpoints being blocked? Why would any be blocked? It's not like and bad actors will stop what their doing because one VPN endpoint was blocked.
Post by dcoke22 » Fri Aug 08, 2025 3:01 pm
If the router at the VPN exit node has geoblocking turned on, it might prevent you from finding the server in Russia hosting the hashed keys.
