How long to get key
Appfel
How long to get key
#1 Post by Appfel » Sun Aug 03, 2025 11:56 am
Hello!
I purchased a licence for MakeMKV, also to get rid of expiring Beta key ;-)
I have not received the key yet (in the email, it said, I would need to contact MakeMKV, which I did). So it seems to had issues or the process is not automatic. Do you know, how long it takes to receive the new key? As the Beta key is expired, I can also not jump back to Beta key while waiting.
mesniu
Re: How long to get key
#2 Post by mesniu » Sun Aug 03, 2025 6:37 pm
same. paid for it a few days ago. contacted support. still waiting here too.
#3 Post by dcoke22 » Mon Aug 04, 2025 1:18 pm
It is my understanding that what should have happened is after PayPro Global accepted payment, they should have emailed you a key. It seems that PayPro Global has run out of a stock of keys to give to customers. They kept accepting payment and told people to contact MakeMKV for a key. Undoubtedly Mike, that author of MakeMKV, was not expecting this to be the case.
I have faith that Mike will fix the situation so that PayPro Global has a stock of keys again and those who have already paid get a working key for the software. Unfortunately I don't have any insight into when all this will get fixed.
Appfel
#4 Post by Appfel » Mon Aug 04, 2025 11:07 pm
Okay, so a mistake on PayPro side. Good to know, thanks a lot!
cydfsa
#5 Post by cydfsa » Tue Aug 05, 2025 4:04 pm
And now the store.payproglobal.com link is non-operative. :(
Stainless
#6 Post by Stainless » Wed Aug 06, 2025 8:11 pm
Well... I can't reply toward the license situation as myself went to buy a license and the store was down... Concerning considering we upgraded our computer setup for this software.
Regardless, I would HIGHLY recommend that everyone downloads the latest version to save a copy, next change your system time back BEFORE July 30th 2025 and then open up MakeMKV after updating your system time & date. This gets around the Licensing issues and allows the Beta License to continue... Not the best solution but a solution that we are grateful for!!
This advise is following the makers recommendation on this forum post: viewtopic.php?f=1&t=20579
EbonHawk
#7 Post by EbonHawk » Thu Aug 07, 2025 11:37 am
I can't believe this actually works, but it does! Or, at least it did when I tried a DVD. Going to have to try a blu-ray next. I swear I tried this in the past before I read about it here, and it DIDN'T work. Oh well, at least it does now. Thanks!
Regardless, I would HIGHLY recommend that everyone downloads the latest version to save a copy, next change your system time back a year and then open up MakeMKV after updating your system time & date. This gets around the Licensing issues and allows the Beta License to continue... Not the best solution but a solution that we are grateful for!!
blaze53
#8 Post by blaze53 » Thu Aug 07, 2025 11:54 pm
There is zero reason to set the date an entire year prior.
EbonHawk
#9 Post by EbonHawk » Fri Aug 08, 2025 3:15 am
I just set mine to July 17, 2025, and it worked fine.
Stainless
#10 Post by Stainless » Fri Aug 08, 2025 6:44 am
Sorry, set it to any date BEFORE July 30 2025... Happy now?
Riesz
#11 Post by Riesz » Fri Aug 08, 2025 2:47 pm
Here's what I did. Make a new text file and paste this into it, changing to your makemkv directory.
@echo off
if not "%1"=="am_admin" (powershell start -verb runas '%0' am_admin & exit /b)
date 05-04-25
time 00:00:00
start /wait "test" "D:\Program Files (x86)\MakeMKV\makemkv.exe"
w32tm /resync
Save as something like makemkv-date-change.bat
