Sleepy Hollow not coming out widescreen
deep1986
Post by deep1986 »
Hi everybody,
I've been trying to rip my Sleepy Hollow DVD but it comes out at 4:3, instead of 16:9.
When I watch the DVD on a normal player it shows as widescreen just not my rips :cry:
Any ideas?
MakeMKV_log.txt
(1.42 KiB) Downloaded 583 times
crowfax
Re: Sleepy Hollow not coming out widescreen
Post by crowfax »
Yup. The DVD is incorrectly mastered, the MPEG2 headers say the stream is 4:3. The reason it works on your DVD player is likely that the VOB files says it's 16:9.
These are the steps you need to take to fix it:
1. Extract the video stream from the MKV with MKVextract (part of the mkvtoolnix package).
2. Download DVD Patcher.
3. Open DVD Patcher and open the MPEG2 steam that you obtained in part 1.
4. Once changed to 16:9 save the file.
5. Remux the video stream created in part 4 with the MKV file using MMG (downloaded with mkvtoolnix), untick the video stream from the MKV file so you don't end up with a video file with 2 video streams.
