Cannot encode MKV files made with MakeMKV with Handbrake
candyman
Post by candyman » Sun Jan 15, 2012 8:52 pm
Hi
I've ripped some BD discs with MakeMKV, directly to MKV not M2TS backup.
Some of these will open up fine in Handbrake but for others I get this error:
"Your source may be copy protected, badly mastered or in a format which Handbrake does not support." errors?
The files are fine and can be opened and played with VLC no problems, so I imagine the problem is the protection hasn't been removed?
Anyone have any ideas what is going on?
candyman
Re: Cannot encode MKV files made with MakeMKV with Handbrake
Post by candyman » Sun Jan 15, 2012 9:07 pm
Just realized that the rip that is working ok with Handbrake was made with v.1.6.5. The ones that are not working are made with v.1.6.7
Is there anyway to correct this as I no longer have the media available to re-rip
Romansh
Post by Romansh » Sun Jan 15, 2012 10:15 pm
Try remuxing MakeMKV 1.6.7's output with the latest mkvmerge GUI. Or re-rip the discs with MakeMKV 1.7.0.
candyman
Post by candyman » Thu Jan 19, 2012 10:13 pm
Damn that didn't work... any other program I can use to encode (shrink) that isnt handbrake?
BlackDragon24
Post by BlackDragon24 » Thu Jan 19, 2012 11:28 pm
candyman wrote:Damn that didn't work... any other program I can use to encode (shrink) that isnt handbrake?
I use Xvid4PSP 5. It is a bit of a steeper learning curve but it works. Ripbot264 works well too.
Romansh
Post by Romansh » Thu Jan 19, 2012 11:52 pm
Probably too many streams. You could try a nightly build of HandBrake (there's an announcement on the HandBrake forum).
Twowit2woo
Post by Twowit2woo » Mon Jan 23, 2012 4:34 pm
www.freemake.com
setarip_old
Post by setarip_old » Mon Jan 23, 2012 5:08 pm
@candyman
Hi!
This is a forum for beta testing MakeMKV with purchased commercial media that you have in your possession. Your posts to this thread state that the .MKVs created directly with MakeMKV play properly and you don't possess original discs - Two reasons that your posts to this thread are inappropriate for this forum...
