With all of the flashing, now my UHD won't play any discs
ZackyDog
#1 Post by ZackyDog » Wed Aug 06, 2025 1:53 am
With all of the flashing I've done, now my UHD won't play any DVDs, Blu-rays or 4k Blu-rays.
I got a used UHD BU40N (internal slim drive) today. At one time, it could play blu-ray discs, but now it won't play any discs.
I was trying to flash it, using the SDFtool Flasher and this bin file: HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.
Does anyone have any ideas how I can fix this?
Thanks for stopping by.
ZackyDog
Re: With all of the flashing, now my UHD won't play any discs
#2 Post by ZackyDog » Wed Aug 06, 2025 5:59 am
I just tried Marty McNuts firmware (BU40N 1.03-MK) and that didn't work.
#3 Post by dcoke22 » Wed Aug 06, 2025 2:43 pm
Try power cycling the drive. And post your current drive info.
ZackyDog
#4 Post by ZackyDog » Wed Aug 06, 2025 5:47 pm
@dcoke22
I did power cycle it. I know the unit can eject and spin the discs, but won't play anything (e.g. DVD, Blu-ray, CD, etc.)
ATA HL-DT-ST BD-RE BU40N
Model: BU40N (ANCK2N0).
#5 Post by MartyMcNuts » Wed Aug 06, 2025 11:51 pm
@dcoke22
How is the drive connected to the PC? If not using an enclosure, you must provide the drive with AC power.
ZackyDog
#6 Post by ZackyDog » Thu Aug 07, 2025 1:06 am
On the back of the BU40N, there's a mini sata port (7 + 6 pin) which is connected to the motherboard of my slimfit HP PC, which is plugged into an electrical outlet in the wall of my home. :wink:
#7 Post by MartyMcNuts » Thu Aug 07, 2025 1:41 am
Ok, so the PC case has a 9.5mm optical drive slot. Are you sure you have connected both sata and power cables to the drive? Or is it a combined 13 pin data/power cable?
ZackyDog
#8 Post by ZackyDog » Thu Aug 07, 2025 2:02 am
The sata and power cables are separate and not combined; they are connected to the drive. I'll double-check to see that the connection is secure/solid.
I know this seems strange, but could I get an adapter like this (13 pin sata to usb) and use 2 of my usb 3.0 inputs on my PC?
#9 Post by MartyMcNuts » Thu Aug 07, 2025 2:43 am
No, these don't work. I've tried one of those before. The adapter itself needs AC power.
I can confirm that both of these SATA to USB powered adapters work with the mini sata adapter.
https://www.amazon.com.au/Alxum-Adapter ... 344&sr=8-3
https://www.amazon.com.au/Adapter-FIDEC ... r=8-6&th=1
Sata mini adapter:
https://www.amazon.com.au/CY-Adapter-Sl ... r=8-1&th=1
ZackyDog
#10 Post by ZackyDog » Thu Aug 07, 2025 8:18 pm
@MartyMcNuts Thanks for all of your help.
ZackyDog
#11 Post by ZackyDog » Thu Aug 07, 2025 8:20 pm
I am deducing that the power supply from my Slimfit HP isn't sufficient for my internal UHD drive(?) Strange because my external lost/stolen Archgon UHD drive worked fine when I connected it to 2 of my USB 3.0 ports.
#12 Post by Coopervid » Thu Aug 07, 2025 8:48 pm
Most of these cheap adapters only support HDDs and not optical drives. Not a power issue. Get one of those Marty recommended.
ZackyDog
#13 Post by ZackyDog » Thu Aug 07, 2025 9:38 pm
I have an adapter like Marty suggested (unfortunately, none of the ones that he suggested are in stock):
But I still can't connect the two.
From what Marty said, there is a power issue and I should use direct AC power (e,g, not via my PC's power supply).
zavili
#14 Post by zavili » Thu Aug 07, 2025 11:19 pm
Hey, I think we are having the same issue. Although mine says it is still original(unpatched) even after flashing many times with sdf and the command line. I also have an HP pc (HP Elitedesk 800 G3) so maybe it is an issue with hp? How can you be sure it is a power issue?
#15 Post by MartyMcNuts » Fri Aug 08, 2025 12:04 am
That unitek one should be fine. Just add a sata to mini sata adaptor and you should be good. I linked to it in my previous post.
