Will there be a new temporary key for August?
Lonald
Post by Lonald »
It appears the current key expired at the end of July.
Anne Hathaway
Re: Will there be a new temporary key for August?
Post by Anne Hathaway »
I noticed that Mike (dev) usually updates the key around the 5th-7th of every month, but sometimes it's late if he's busy or there's a big update. Do you think they're preparing to release a new update?
Jenne99
Post by Jenne99 »
Hallo,
mein MKV funktioniert seit 01.08.25 nicht mehr.
Wird es Lösung dafür geben ?
My MKV file hasn't worked since August 1, 2025.
Will there be a solution?
Gruß JG
ivan@toulousenet.de
Post by ivan@toulousenet.de »
No one knows at the moment. But my hopes are fading day by day as we receive no news about what will happen next.
Smithcraft
Post by Smithcraft »
Mike seems to be away from the site right now, so you won't even be able to buy a key.
You'll just have to keep watching the forums and see what happens with the purchased key issue that people are having. Or you can keep an eye on the purchase site since they are not selling keys until Mike gets back to them.
SC
MilesJohnson
Post by MilesJohnson »
If only there was a way to go back to a time when the key did work.
Lonald
Post by Lonald »
Got it, thanks!
maczrool
Post by maczrool »
On my Windows 11 changing the date to July 6th allows it to run without complaining about it being too old but when I actually try to rip a disc, it says the evaluation period is over and it won't rip it.
ak1978
Post by ak1978 »
maczrool wrote: Wed Aug 06, 2025 3:44 pm On my Windows 11 changing the date to July 6th allows it to run without complaining about it being too old but when I actually try to rip a disc, it says the evaluation period is over and it won't rip it.
I had that issue as well, but you just have to re-register with the old beta key while your clock is in the past.
After that, make sure you only start the program when you're in July, otherwise the key will "expire" again.
