MKV hasn't worked since August 1, 2025
Jenne99
Post by Jenne99 »
Hallo,
mein MKV funktioniert seit 01.08.25 nicht mehr.
Wird es Lösung dafür geben ?
Es gebt weder eine neue Lizemz, noch kann man das Programm kaufen.
Weis einer Rat ?
Gruß JG
My MKV hasn't worked since August 1, 2025.
Is there a solution?
There's no new license available, nor can I purchase the program.
Does anyone have any advice?
Regards, JG
Re: MKV hasn't worked since August 1, 2025
At the moment, all you can do is continue to wait. It is up to Mike to post a new beta key and to sort out the backend problems related to purchasing a permanent key. Hopefully he'll get the issues fixed soon.
