Revert to DVD Only
TripleS
Revert to DVD Only
Post by TripleS »
I have the latest version of MakeMKV (1.18.1) installed. I needed to do some blu-ray ripping so I added the temp key found here on the forum and I was able to do what I needed. Now, the time is up on the key and the application won't launch without installing the latest version again. Since there isn't yet a new version, this isn't possible.
Is there as way to revert the application back to working for DVD's only like before I entered the key?
Re: Revert to DVD Only
The problem is the key for the whole program is expired, if you do not have a registration. You need to set your system date to sometime in July (pre-August 1), start the program, then you can do what you want with the date,
This should be fixed when Mike returns, but we do no know when that will be.
TripleS
Post by TripleS »
Roger. Thanks Woodstock.
