Most likely they are now LG drives instead of Pioneer but post the Makemkv info for both when you get them.
Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Maybe I got lucky?
Pioneer UD03
Pioneer UD03
I tried, but "the board attachment quota has been reached". Let me know what info you need and I will include it here. Here's some to start off:
Drive Info
BD-RW BDR-UD03
Revision 1.14
Firmware date: 2020-06-15
Bus Encryption flags: 1B
Highest AACS version: 77
LibreDrive Info
Status Enabled
Drive Platform: RS8511
Firmware verison: 1.14
Drive Info
BD-RW BDR-UD03
Revision 1.14
LibreDrive Info
Status Enabled
That's absolutely fine. PM sent.fitbrit wrote: ↑Tue Aug 05, 2025 5:20 pmI tried, but "the board attachment quota has been reached". Let me know what info you need and I will include it here. Here's some to start off:
Drive Info
BD-RW BDR-UD03
Revision 1.14
LibreDrive Info
Status Enabled
Thanks - all worked great!
I have Verbaim Drive 43890
Any chance?Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: BADL473915WL
Firmware-Datum: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
Disk-Informationen
Label: SONIC_THE_HEDGEHOG_2
Zeitstempel: 2022-06-10 10:29:06
Schutz: AACS v68
Datenkapazität: 43.6 Gb
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Kanal-Bitlänge: 74,5 nm (max. 25.0 GB pro Layer)
Yeah email me that infotheDark wrote: ↑Wed Aug 13, 2025 5:04 pmI have Verbaim Drive 43890
Produzent: PIONEER
Revision: 1.14
Disk-Informationen
Schutz: AACS v68
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Master2002
I bought one of these from Staples about a year ago, any chance it can do UHD?
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: CIDL502933WL
Highest AACS version: 81
Revision: 1.14
Yes email me that drive info see belowMaster2002 wrote: ↑Thu Aug 14, 2025 7:02 pmI bought one of these from Staples about a year ago, any chance it can do UHD?
Revision: 1.14
orbitalUHD
I have the exact same thing. Can you also do it for me too pls?
Revision: 1.14
Serial number: DGDL539709WL
Revision: 1.14
PM sent.orbitalUHD wrote: ↑Fri Aug 15, 2025 1:28 amI have the exact same thing. Can you also do it for me too pls?
Revision: 1.14
Does Verbatim 43890 after changing firmware only read 100GB discs or can write too? Or shoul I change for something else? Is 43888 good for burning?
Dear @Coopervid
Is is possible to make it to write on 100gb disc and to be readable in bluraplayer:
Aktualny profil: BD-ROM
Producent: PIONEER
Wersja: 1.14
Numer seryjny: TJDL356149WL
Data firmware: 2020-06-15
Flagi szyfrowania bus: 1B
Najwyższa wersja AACS: 63
PM sent. Will read UHD and write BDXL.matt12345 wrote: ↑Mon Sep 08, 2025 11:54 amDear @Coopervid
Is is possible to make it to write on 100gb disc and to be readable in bluraplayer:Aktualny profil: BD-ROM
Producent: PIONEER
Wersja: 1.14
