Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
#721 Post by Coopervid » Wed Jul 09, 2025 10:40 am
At least we have clarified one point. You were talking about your UD03 but since it's flashed already to UD04 you should have called it UD04. And that was the Makemkv info you posted above.
dtech
#722 Post by dtech » Wed Jul 16, 2025 2:58 pm
I would also like some help with my drive, if possible. The drive information is as follows:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03D
Revision: 1.00
Serial number: OBDL035864WL
Firmware date: 2014-05-14
Highest AACS version: 68
Drive platform: RS8510
Firmware version: 1.00/ID84
Thanks in advance.
#723 Post by Coopervid » Wed Jul 16, 2025 3:15 pm
dtech wrote: Wed Jul 16, 2025 2:58 pm I would also like some help with my drive, if possible. The drive information is as follows:
OS device name: F:
Revision: 1.00
Thanks in advance.
PM sent.
eRGo1986
Verbatim 43890 branded Pioneer BDR-UD03
#724 Post by eRGo1986 » Wed Jul 16, 2025 7:27 pm
Hello Coopervid & Co.!
I own an external Verbatim branded USB 3.0 slimline Blu-ray writer (Verbatim#43890) from Pioneer and want to enhance it (and alo prevent it from "forced software degration"):
MakeMKV v1.18.1 win(x64-release) gestartet
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.11
Serienummer: ------------
Firmware-Datum: 2018-11-28
Highest AACS version: 62
Drive platform: RS8511
Firmware version: 1.11
Keine Disk eingelegt
I'll appreciate it if you could send me that special PM :-).
Greetings
eRGo1896
Re: Verbatim 43890 branded Pioneer BDR-UD03
#725 Post by Coopervid » Wed Jul 16, 2025 8:28 pm
eRGo1986 wrote: Wed Jul 16, 2025 7:27 pm Hello Coopervid & Co.!
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
Greetings
eRGo1896
PM sent.
J8GDN
#726 Post by J8GDN » Thu Jul 17, 2025 9:16 am
any help appreciated - looks to have old firmware and can this be flashed to enable UHD - novice so bear with me. thanks J
Revision: 1.10
Serial number: ...
Firmware date: 2017-04-18
Highest AACS version: 76
Firmware version: 1.10
#727 Post by Billycar11 » Thu Jul 17, 2025 2:36 pm
J8GDN wrote: Thu Jul 17, 2025 9:16 am any help appreciated - looks to have old firmware and can this be flashed to enable UHD - novice so bear with me. thanks J
Revision: 1.10
Serial number: ...
Sure email me that drive info see below
J8GDN
#728 Post by J8GDN » Fri Jul 18, 2025 7:25 pm
cheers, will sort on Monday
joshi21
#729 Post by joshi21 » Sun Aug 03, 2025 12:45 am
Coopervid wrote: Wed Jul 16, 2025 8:28 pm
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
Greetings
eRGo1896
PM sent.
Hi Coopervid,
I also have a PIONEER BD-RW BDR-UD03 with fw 1,14 and need help to make it UHD ready. Can you help me?
#730 Post by Coopervid » Sun Aug 03, 2025 9:34 am
joshi21 wrote: Sun Aug 03, 2025 12:45 am
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
Greetings
eRGo1896
PM sent.
Hi Coopervid,
Please post your own Makemkv info.
joshi21
#731 Post by joshi21 » Mon Aug 04, 2025 8:12 pm
Coopervid wrote: Sun Aug 03, 2025 9:34 am
Here it is:
OS-Gerätename: /dev/rdisk6
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Revision: 1.14
Serienummer: CIDL505512WL
Firmware-Datum: 2020-06-15
Highest AACS version: 20
Firmware version: 1.14
BD raw metadata read: Yes Unrestricted read speed: Yes
PM sent.
Hi Coopervid,
#732 Post by Coopervid » Mon Aug 04, 2025 8:21 pm
joshi21 wrote: Mon Aug 04, 2025 8:12 pm
Hi Coopervid,
PM sent. Wanted to make sure it's not a combo that can't be flashed.
joshi21
#733 Post by joshi21 » Tue Aug 05, 2025 7:25 pm
Coopervid wrote: Mon Aug 04, 2025 8:21 pm
Hi, thank you for your PM. I tried it an unfortunately the Software shows "Selected drive is not a Pioneer drive". Although the dropdown lists it as a Pioneer.
#734 Post by Coopervid » Wed Aug 06, 2025 4:41 am
Use a Windows PC or VMware. You seem to be on Linux and that is the issue.
joshi21
#735 Post by joshi21 » Wed Aug 06, 2025 5:55 pm
Coopervid wrote: Wed Aug 06, 2025 4:41 am Use a Windows PC or VMware. You seem to be on Linux and that is the issue.
No I use a M1 Max MacBook Pro running Windows 11 with Parallels.
