Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
#226 Post by Coopervid » Mon Aug 04, 2025 8:31 pm
fitbrit wrote: Mon Aug 04, 2025 8:26 pm @coopervid
I just bought two of these drives from staples.
Hoping that you might be able to help me once I get them and post the info here.
Thanks very much for helping all of us in this thread!
Most likely they are now LG drives instead of Pioneer but post the Makemkv info for both when you get them.
fitbrit
#227 Post by fitbrit » Tue Aug 05, 2025 3:44 pm
Maybe I got lucky?
Pioneer UD03
#228 Post by Coopervid » Tue Aug 05, 2025 4:51 pm
fitbrit wrote: Tue Aug 05, 2025 3:44 pm Maybe I got lucky?
Pioneer UD03
Great! Post your Makemkv info and you will receive a PM:
fitbrit
#229 Post by fitbrit » Tue Aug 05, 2025 5:20 pm
I tried, but "the board attachment quota has been reached". Let me know what info you need and I will include it here. Here's some to start off:
Drive Info
BD-RW BDR-UD03
Revision 1.14
Firmware date: 2020-06-15
Bus Encryption flags: 1B
Highest AACS version: 77
LibreDrive Info
Status Enabled
Drive Platform: RS8511
Firmware verison: 1.14
#230 Post by Coopervid » Tue Aug 05, 2025 5:23 pm
fitbrit wrote: Tue Aug 05, 2025 5:20 pm I tried, but "the board attachment quota has been reached". Let me know what info you need and I will include it here. Here's some to start off:
Drive Info
BD-RW BDR-UD03
Revision 1.14
LibreDrive Info
Status Enabled
That's absolutely fine. PM sent.
fitbrit
#231 Post by fitbrit » Tue Aug 05, 2025 7:48 pm
Thanks - all worked great!
theDark
#232 Post by theDark » Wed Aug 13, 2025 5:04 pm
I have Verbaim Drive 43890
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: BADL473915WL
Firmware-Datum: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
Disk-Informationen
Label: SONIC_THE_HEDGEHOG_2
Zeitstempel: 2022-06-10 10:29:06
Schutz: AACS v68
Datenkapazität: 43.6 Gb
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Kanal-Bitlänge: 74,5 nm (max. 25.0 GB pro Layer)
Any chance?
#233 Post by Billycar11 » Wed Aug 13, 2025 5:47 pm
theDark wrote: Wed Aug 13, 2025 5:04 pm I have Verbaim Drive 43890
Produzent: PIONEER
Revision: 1.14
Disk-Informationen
Schutz: AACS v68
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Any chance?
Yeah email me that info
Master2002
#234 Post by Master2002 » Thu Aug 14, 2025 7:02 pm
I bought one of these from Staples about a year ago, any chance it can do UHD?
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: CIDL502933WL
Highest AACS version: 81
#235 Post by Billycar11 » Thu Aug 14, 2025 7:32 pm
Master2002 wrote: Thu Aug 14, 2025 7:02 pm I bought one of these from Staples about a year ago, any chance it can do UHD?
Revision: 1.14
Yes email me that drive info see below
orbitalUHD
#236 Post by orbitalUHD » Fri Aug 15, 2025 1:28 am
I have the exact same thing. Can you also do it for me too pls?
Revision: 1.14
Serial number: DGDL539709WL
#237 Post by Coopervid » Fri Aug 15, 2025 8:59 am
orbitalUHD wrote: Fri Aug 15, 2025 1:28 am I have the exact same thing. Can you also do it for me too pls?
Revision: 1.14
PM sent.
matt12345
#238 Post by matt12345 » Mon Sep 08, 2025 7:46 am
Does Verbatim 43890 after changing firmware only read 100GB discs or can write too? Or shoul I change for something else? Is 43888 good for burning?
matt12345
#239 Post by matt12345 » Mon Sep 08, 2025 11:54 am
Dear @Coopervid
Is is possible to make it to write on 100gb disc and to be readable in bluraplayer:
Aktualny profil: BD-ROM
Producent: PIONEER
Wersja: 1.14
Numer seryjny: TJDL356149WL
Data firmware: 2020-06-15
Flagi szyfrowania bus: 1B
Najwyższa wersja AACS: 63
#240 Post by Coopervid » Mon Sep 08, 2025 4:30 pm
matt12345 wrote: Mon Sep 08, 2025 11:54 am Dear @Coopervid
Producent: PIONEER
Wersja: 1.14
PM sent. Will read UHD and write BDXL.
