Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
fitbrit wrote:
Mon Aug 04, 2025 8:26 pm
@coopervid
I just bought two of these drives from staples.
Hoping that you might be able to help me once I get them and post the info here.
Thanks very much for helping all of us in this thread!
Most likely they are now LG drives instead of Pioneer but post the Makemkv info for both when you get them.
fitbrit
Post by fitbrit »
Maybe I got lucky?
Pioneer UD03
fitbrit wrote:
Tue Aug 05, 2025 3:44 pm
Maybe I got lucky?
Pioneer UD03
Great! Post your Makemkv info and you will receive a PM:
fitbrit
Post by fitbrit »
I tried, but "the board attachment quota has been reached". Let me know what info you need and I will include it here. Here's some to start off:
Drive Info
BD-RW BDR-UD03
Revision 1.14
Firmware date: 2020-06-15
Bus Encryption flags: 1B
Highest AACS version: 77
LibreDrive Info
Status Enabled
Drive Platform: RS8511
Firmware verison: 1.14
fitbrit wrote:
Tue Aug 05, 2025 5:20 pm
Drive Info
BD-RW BDR-UD03
Revision 1.14
LibreDrive Info
Status Enabled
That's absolutely fine. PM sent.
fitbrit
Post by fitbrit »
Thanks - all worked great!
theDark
Post by theDark »
I have Verbaim Drive 43890
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: BADL473915WL
Firmware-Datum: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
Disk-Informationen
Label: SONIC_THE_HEDGEHOG_2
Zeitstempel: 2022-06-10 10:29:06
Schutz: AACS v68
Datenkapazität: 43.6 Gb
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Kanal-Bitlänge: 74,5 nm (max. 25.0 GB pro Layer)
Any chance?
theDark wrote:
Wed Aug 13, 2025 5:04 pm
Produzent: PIONEER
Revision: 1.14
Disk-Informationen
Schutz: AACS v68
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Any chance?
Yeah email me that info
Master2002
Post by Master2002 »
I bought one of these from Staples about a year ago, any chance it can do UHD?
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: CIDL502933WL
Highest AACS version: 81
Master2002 wrote:
Thu Aug 14, 2025 7:02 pm
Revision: 1.14
Yes email me that drive info see below
orbitalUHD
Post by orbitalUHD »
I have the exact same thing. Can you also do it for me too pls?
Revision: 1.14
Serial number: DGDL539709WL
orbitalUHD wrote:
Fri Aug 15, 2025 1:28 am
Revision: 1.14
PM sent.
matt12345
Post by matt12345 »
Does Verbatim 43890 after changing firmware only read 100GB discs or can write too? Or shoul I change for something else? Is 43888 good for burning?
matt12345
Post by matt12345 »
Dear @Coopervid
Is is possible to make it to write on 100gb disc and to be readable in bluraplayer:
Aktualny profil: BD-ROM
Producent: PIONEER
Wersja: 1.14
Numer seryjny: TJDL356149WL
Data firmware: 2020-06-15
Flagi szyfrowania bus: 1B
Najwyższa wersja AACS: 63
matt12345 wrote:
Mon Sep 08, 2025 11:54 am
Dear @Coopervid
Producent: PIONEER
Wersja: 1.14
PM sent. Will read UHD and write BDXL.
