How long to get key
Appfel
How long to get key
Post by Appfel » Sun Aug 03, 2025 11:56 am
Hello!
I purchased a licence for MakeMKV, also to get rid of expiring Beta key ;-)
I have not received the key yet (in the email, it said, I would need to contact MakeMKV, which I did). So it seems to had issues or the process is not automatic. Do you know, how long it takes to receive the new key? As the Beta key is expired, I can also not jump back to Beta key while waiting.
mesniu
Re: How long to get key
Post by mesniu » Sun Aug 03, 2025 6:37 pm
same. paid for it a few days ago. contacted support. still waiting here too.
Post by dcoke22 » Mon Aug 04, 2025 1:18 pm
It is my understanding that what should have happened is after PayPro Global accepted payment, they should have emailed you a key. It seems that PayPro Global has run out of a stock of keys to give to customers. They kept accepting payment and told people to contact MakeMKV for a key. Undoubtedly Mike, that author of MakeMKV, was not expecting this to be the case.
I have faith that Mike will fix the situation so that PayPro Global has a stock of keys again and those who have already paid get a working key for the software. Unfortunately I don't have any insight into when all this will get fixed.
Appfel
Post by Appfel » Mon Aug 04, 2025 11:07 pm
dcoke22 wrote: Mon Aug 04, 2025 1:18 pm It seems that PayPro Global has run out of a stock of keys to give to customers. They kept accepting payment and told people to contact MakeMKV for a key.
Okay, so a mistake on PayPro side. Good to know, thanks a lot!
cydfsa
Post by cydfsa » Tue Aug 05, 2025 4:04 pm
And now the store.payproglobal.com link is non-operative. :(
Stainless
Post by Stainless » Wed Aug 06, 2025 8:11 pm
Well... I can't reply toward the license situation as myself went to buy a license and the store was down... Concerning considering we upgraded our computer setup for this software.
Regardless, I would HIGHLY recommend that everyone downloads the latest version to save a copy, next change your system time back BEFORE July 30th 2025 and then open up MakeMKV after updating your system time & date. This gets around the Licensing issues and allows the Beta License to continue... Not the best solution but a solution that we are grateful for!!
This advise is following the makers recommendation on this forum post: viewtopic.php?f=1&t=20579
EbonHawk
Post by EbonHawk » Thu Aug 07, 2025 11:37 am
I can't believe this actually works, but it does! Or, at least it did when I tried a DVD. Going to have to try a blu-ray next. I swear I tried this in the past before I read about it here, and it DIDN'T work. Oh well, at least it does now. Thanks!
Stainless wrote: Wed Aug 06, 2025 8:11 pm Well... I can't reply toward the license situation as myself went to buy a license and the store was down... Concerning considering we upgraded our computer setup for this software.
Regardless, I would HIGHLY recommend that everyone downloads the latest version to save a copy, next change your system time back a year and then open up MakeMKV after updating your system time & date. This gets around the Licensing issues and allows the Beta License to continue... Not the best solution but a solution that we are grateful for!!
blaze53
Post by blaze53 » Thu Aug 07, 2025 11:54 pm
There is zero reason to set the date an entire year prior.
EbonHawk
Post by EbonHawk » Fri Aug 08, 2025 3:15 am
I just set mine to July 17, 2025, and it worked fine.
blaze53 wrote: Thu Aug 07, 2025 11:54 pm There is zero reason to set the date an entire year prior.
Stainless
Post by Stainless » Fri Aug 08, 2025 6:44 am
Sorry, set it to any date BEFORE July 30 2025... Happy now?
Riesz
Post by Riesz » Fri Aug 08, 2025 2:47 pm
Here's what I did. Make a new text file and paste this into it, changing to your makemkv directory.
@echo off
if not "%1"=="am_admin" (powershell start -verb runas '%0' am_admin & exit /b)
date 05-04-25
time 00:00:00
start /wait "test" "D:\Program Files (x86)\MakeMKV\makemkv.exe"
w32tm /resync
Save as something like makemkv-date-change.bat
blaze53
Post by blaze53 » Fri Aug 08, 2025 9:15 pm
Stainless wrote: Fri Aug 08, 2025 6:44 am
Well, considering that setting the system time too far back would cause issues with key retrieval... yes.
mlm123
Post by mlm123 » Fri Aug 08, 2025 10:00 pm
Riesz wrote: Fri Aug 08, 2025 2:47 pm Here's what I did. Make a new text file and paste this into it, changing to your makemkv directory.
@echo off
date 05-04-25
time 00:00:00
w32tm /resync
".exe," ".bat"? Did you look to see which forum you're in?
Skyseafuurinkazan
Post by Skyseafuurinkazan » Sat Aug 09, 2025 9:13 am
dcoke22 wrote: Mon Aug 04, 2025 1:18 pm It is my understanding that what should have happened is after PayPro Global accepted payment, they should have emailed you a key. It seems that PayPro Global has run out of a stock of keys to give to customers. They kept accepting payment and told people to contact MakeMKV for a key. Undoubtedly Mike, that author of MakeMKV, was not expecting this to be the case.
It looks like PayPro Global expected to be MakeMkv directly to send the link, and they weren't aware of the situation.
I purchased the license key on August 2nd, received an email from PayPro Global with the purchase details and on it they wrote to contact MakeMkv support to get the key, so I did it.
After 2 days they hadn't replied yet, so I contacted PayPro Global support, and they emailed MakeMkv support themselves, they got no answers as well. on August 6th I contacted again PayPro Global and they refunded me, saying MakeMkv support didn't reply to them at all, and the only thing they could do was refunding me while waiting for an answer from MakeMkv.
Well, i guess all we can do is waiting for answers.
Keiyuu
Post by Keiyuu » Sat Aug 09, 2025 12:20 pm
mlm123 wrote: Fri Aug 08, 2025 10:00 pm
@echo off
date 05-04-25
time 00:00:00
w32tm /resync
What are you confused about? It's a simple script to automate the process every time you launch MakeMKV, and then automatically sync it to the correct time.
