#196
Post
by Woodstock » Sun Jul 13, 2014 10:32 pm
No need to resurrect a long-passed topic like this. The key thing is this line:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00066.m2ts' at offset '20759248896'
Your drive says there is a problem with the disk. Extending the retries causes MakeMKV to request it to try more, but, if the drive fails after the extra tries, there isn't a whole lot MakeMKV can do about it.
Does the disk LOOK clean, or you cleaned it? I clean any disk that gives errors like this with furniture wax, which will fill in tiny scratches that are difficult to see. I also have multiple drives available (different machines), because sometimes the alignment of the laser in one will be different enough that a disk can be read without error.
raddoc
#197
Post
by raddoc » Sun Jul 13, 2014 11:25 pm
thanks - tried on multiple blue ray readers/burners. Will try the furniture wax!
troyBORG
#198
Post
by troyBORG » Wed Apr 06, 2016 4:50 am
THE_FORCE_AWAKENS
When I try to Rip, or Backup and Decode it gets stuck. So I tried to backup without decrypting and I get:
MakeMKV v1.9.9 win(x64-release) started
Backing up disc into folder "I:/Video/backup/THE_FORCE_AWAKENS"
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00153.m2ts' at offset '7301627904'
Backup failed
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00153.m2ts' at offset '7301167104'
Backup failed
OS device name: J:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Serial number: NCDL010150WL
Firmware details: intf=SAT gen=8600 krnl=ID44 main=ID44 ver=0000
Firmware date: 2013-09-10
Highest AACS version: 57
Disc Information
Label: THE_FORCE_AWAKENS
Timestamp: 2016-02-11 11:03:45
Data capacity: 39.16 Gb
Disc type: BD-ROM
Number of layers: 2
#199
Post
by Woodstock » Wed Apr 06, 2016 2:34 pm
And yet,
others aren't having a problem with the disks, other than finding out which of the three play lists is correct for their chosen language...
troyBORG
#200
Post
by troyBORG » Wed Apr 06, 2016 5:14 pm
After looking at the disc it looked really weird compared to normal. Took it back to the store and exchanged for a new copy which didn't have the same defect when you looked at the disc, and reads perfectly.
Perene
#201
Post
by Perene » Wed Jul 25, 2018 7:41 pm
slade37 wrote:Star Trek The Original Series - Season 1 Blu-Ray - US Release.
It failed to save the MKV files for the episodes. No trouble with the extras that it could read. The episodes have multiple angles (original and new CGI effects). That's the only unique thing I can think of about this title.
This is not part of the box set with all 3 seasons. I know season 3 and the box set hasn't been released at the time of this writing. I'm saying that for anyone reading this months from now.
Had this same problem just now.
It simply says "FAILED TO SAVE AS MKV" for the episodes, even if you only select each one, individually. And it happens with the recent MAKEMKV 1.12.3 version.
Why is that?
averydxf
#202
Post
by averydxf » Fri Aug 24, 2018 8:39 am
The Departed (2006) NTSC DVD AC3 DD5.1 - Failed during the creation of a .mkv file with no reason given for error.
#203
Post
by Woodstock » Fri Aug 24, 2018 1:33 pm
Failures with v1.12.3 are wide-spread.
My personal recommendation is to go back to 1.12.2
unless you need to create a UHD dump file.
Where to find 1.12.2:
https://makemkv.com/download/old/
Why you might need 1.12.3 installed: UHD dump file format changed at 1.12.3, and new submissions for "missing keys" need to be made with 1.12.3 or later.
klaus_moers
#204
Post
by klaus_moers » Fri Apr 26, 2019 7:14 am
I tried "Legends of Jazz", a Bluray with Ramsey Lewis.
Makemkv (Ma OS) cannot work with this Bluray unfortunately.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0B0CE5260DC5876EF9610DE180B5EBF1D34 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..01080924B2CC86707F1E503CCFE3DCD7D92 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..066EB45AF341ECC5EDFEB5E98D95F427E8E to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0872E07C3B0DF31CAB5656596864DC44BE8 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0FDCBE38106F7F0953240462EC740E8B766 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0FD946F464608E17A4058B3F5F27C533AA9 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..01CF45D93B5507BCB6C21A364507D8ED163 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0E88226C981E254030E4D680E366E31DE22 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0E6AB384CE6B9C0EA11F4D35029D040E088 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0B90449B298C0FBBFDAA963FEA20E88CB51 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0DFA7981511BCA5DA90C665072C49CD614E to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0D02D2508A5B0DD60900073215627C14845 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0DDE45074F95A592138DAC1ED388C4AA323 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09202AC131BE6783025270F4B349CE393DC to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0317C9BDF5EC6C0316A419B052B4645CA66 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..073D708445AB927B11148FF6B589882B1B3 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..08275A318633EA2E4ADF7E95B9BF6E653D5 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..08816B9378958E40AEE0B6A4EF2240B23DB to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..073D61825EF20E09C6D823199C3CA4A5EDE to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..07DED8ECDC7F5EA494861DBD413DC948CD6 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0A8541F0D6268FC9D5294CEA1874EA2B58D to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0D91049934DD488F73391989D544FCD0D35 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..076AE651624939AE404AA87A3DC929BB9B1 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09A952B52C2F536058CD638C3D3D05C94C6 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0040DC509CFE592CDFFDBFDBC431D7E4F44 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..062D5EB305DB88A5A419D8479B65DADCDF1 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0CF4015BDD3B0A032F13D405C3F533E60C6 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0DDA29AEEECD48ABA5193A9C41EDD004446 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0107BCFAE46319379263E622F80BA919673 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0136610999126D0E18BA9F9A354F4E31F65 to device 'IoKit:IOBDServices:af0a60bb4d8b9887:TSSTcorp BDDVDW SE-506AB TS00'
Saved AACS dump file as /Users/klaus/Library/MakeMKV/MKB_v1_LOGICAL_VOLUME_ID_EEDA.tgz
#205
Post
by Woodstock » Fri Apr 26, 2019 12:55 pm
Those errors look like the drive cannot read the inner part of the disk (where the AACS and directory information are stored), and MakeMKV cannot compute a decryption key for it.
If you're experiencing rip errors, please read here first!
PsychoBat
#206
Post
by PsychoBat » Mon Aug 04, 2025 2:18 am
Death Race 2000 (DVD, 1998) printed by Digital Multimedia Limited.
After multiple ripping attempts, the finalized mkv is only the first 8 minutes and 59 seconds of the film.
The DVD will play fine in any player, so this particular copy is not the issue.
