1.18.1 version is too old error
jw123
#1 Post by jw123 » Fri Aug 01, 2025 8:14 pm
I just opened the MakeMKV app to finish ripping some discs, and when I opened it, it gave me an error message saying the version is too old. I thought that maybe there was an update, and it did not update, so I deleted the app and reinstalled it, and it still gives me the error message. Has anybody else had this problem? I used this app yesterday without any problems, and now it's not working. What should I do? Thanks for the help
Screenshot 2025-08-01 151015.png (60.72 KiB) Viewed 40330 times
Re: 1.18.1 version is too old error
#2 Post by d00zah » Fri Aug 01, 2025 11:20 pm
jw123 wrote: Fri Aug 01, 2025 8:14 pm I just opened the MakeMKV app to finish ripping some discs, and when I opened it, it gave me an error message saying the version is too old. I thought that maybe there was an update, and it did not update, so I deleted the app and reinstalled it, and it still gives me the error message. Has anybody else had this problem? I used this app yesterday without any problems, and now it's not working. What should I do? Thanks for the help
Stephen
#3 Post by Stephen » Fri Aug 01, 2025 11:30 pm
I am having the same problem. But i have found a temporary work around. You need to run a command prompt and change the date back to the end of July
bolin
#4 Post by bolin » Sat Aug 02, 2025 2:36 am
Same for me, I have the latest version but I get the same message. What can we do?
bolin
#5 Post by bolin » Sat Aug 02, 2025 3:11 am
Stephen wrote: Fri Aug 01, 2025 11:30 pm I am having the same problem. But i have found a temporary work around. You need to run a command prompt and change the date back to the end of July
Can you explain how to do that?
Stephen
#6 Post by Stephen » Sat Aug 02, 2025 3:45 am
on windows 11
click on search
type in cmd
select run as administrator and yes to question
type in date
enter new date (as per country format) and press enter
restart program
jeffh2o
#7 Post by jeffh2o » Sat Aug 02, 2025 3:55 pm
Thanks Stephen!!
I hadn't thought of sending my computer Back 2 The Future. :)
Nice work around until a new version or reg key update is available.
Luv this program. :D
bolin
#8 Post by bolin » Sat Aug 02, 2025 5:56 pm
Thank you.
If someone has a permanent solution that would be great!!
mlm123
#9 Post by mlm123 » Sat Aug 02, 2025 7:17 pm
Anyone have instructions on how to change the date on a Mac? I purchased a permanent license, but am waiting for the key.
ak1978
#10 Post by ak1978 » Sat Aug 02, 2025 9:56 pm
Well, it's pretty clear to me.
Because the program is in beta stage, version 1.18.1 has an expiration date, which coincidentally was the same date the beta key expired, namely August 1st, 2025.
Mike will either just create a new beta key, and like the message says, once you have a working key, the program will continue to work.
And possibly, there will be a new version soon as well.
If you want a permanent solution, you just have to buy a permanent key. But there are some issues with that currently.
So, we all just have to be patient for a new beta key to be published, and new permanent keys to be made as well.
Until then, there's nothing anyone can do.
jeffh2o
#11 Post by jeffh2o » Sat Aug 02, 2025 10:13 pm
For anyone who's not comfortable using command prompts,
can also temporarily change the date (on Windows 10): :D
search for/open Settings
go to Time & Language, then Date & time
turn Off Set time automatically
Change date manually, then Change
When finished using MakeMKV, turn Set time auto back On to reset date/time.
Sorry, I don't own a Mac but, according to Google, Date setting
should be in the Apple menu > System Settings, General, Date & Time.
mlm123
#12 Post by mlm123 » Sun Aug 03, 2025 5:02 am
jeffh2o wrote: Sat Aug 02, 2025 10:13 pm For anyone who's not comfortable using command prompts,
Thanks for the advice. I had seen that before, but it seemed too simple. Needless to say, it worked.
NFS47
#13 Post by NFS47 » Sun Aug 03, 2025 12:43 pm
That worked perfect, thank you!
seanrt
#14 Post by seanrt » Sun Aug 03, 2025 6:04 pm
That works perfect for me. Thank you at least I can now use my new flashed drive and give it a run.
jeffh2o
#15 Post by jeffh2o » Sun Aug 03, 2025 6:36 pm
No problem, glad I could help with your date changes. :)
Thanks again to Stephen for coming up with the brilliant temporary date change fix earlier. :D
