Has anyone been able to test MacOS 15.5 yet?
Konten
Before installing just wanted to find out whether there are any issues with MakeMKV...
Thanks, guys!!
Thanks, guys!!
Mkvdsch
Re: Has anyone been able to test MacOS 15.5 yet?
No issues so far for me since updating to Mac OS 15.5 on the MacBook Air M1. Although I can only speak considering normal BD not 4K.
Konten
Brilliant, thanks!!
wstarkweather
Mine won't work, worked fine on previous version of 15, but 15.5 it will not work. I disabled gatekeeper, and tried the code from Mike in terminal and I get a fatal error message.
seamus
I successfully installed MakeMKV ver 1.18.1 on a macOS 15.5 just a few days ago. It was an iMac with an Intel processor - not the ARM processor.
TeKno Ziz
I installed and ran it yesterday, ripped a Blu-ray disk, apparently failed. Today I ran the app and MacOS said it wouldn't run it because it could verify whether it had malware.
Update: ran the terminal command to remove Gatekeeper and it worked fine.
danielsmith
I haven't tested MacOS 15.5 yet, but I'm curious to see how it performs with MakeMKV as well. I had a smooth experience with the previous version, so I'm hoping for the same this time. If anyone has tried it, please share your insights!
runezen
Purchased license but no emails yet with the actual key. Anyone? Used the beta version for many years and thought I'd support the development.
Think twice before purchasing a permanent license because chances are you might never receive the mail with the actual KEY.
runezen
"Your version it too old" is all I'm getting. And yes, I've tried re-downloading, re-installing etc. Also paid for a permanent key here but haven' received a confirmation email with the KEY.
karolchilinski
It also says it for me also. Let's notify them.
karolchilinski
Change your Macs date.
