How do I choose the right title - having two identical ones?
Bl4ckShadow
Post by Bl4ckShadow » Thu Jan 12, 2012 6:23 am
I think the title describes my problem pretty much. I want to rip my Bluray "Pirates of the Caribbean: On Stranger Tides" onto my PC and in the list on the left I get two identical titles (see added screenshot, yellow marked), most likely this is made intentionally by Disney for preventing ripping etc..
Now how do I distinguish between the right and false one? Both have the identical size and amout of chapters...
Thanks for any help in advance. :)
Smithcraft
Re: How do I choose the right title - having two identical o
Post by Smithcraft » Thu Jan 12, 2012 9:12 am
BDInfo might be able to help.
SC
Bl4ckShadow
Post by Bl4ckShadow » Thu Jan 12, 2012 11:50 am
Hey SC, thanks for your answer. I already tried scanning with BDInfo, but didn't get much smarter...
Screen with the comparison of the two titles is here:
Romansh
Post by Romansh » Thu Jan 12, 2012 5:20 pm
The first stream of each playlist has the same duration but is different (00726.M2TS vs. 00745.M2TS).
If you use the backup function, you can check the two files (found in BDMV/STREAM/) to see what the difference is.
You might also try using the streaming feature to compare the titles.
Smithcraft
Post by Smithcraft » Thu Jan 12, 2012 10:46 pm
At the home page(or at least I presume it to be the home page) for BDInfo, there is a link to the AVS Forums where a database of sorts has been set up for this sort of thing.
http://www.avsforum.com/avs-vb/showthread.php?t=1155731
When picking the section for Pirates, and then scrolling through the list, I'm guessing that(and I forget the silliness of BD region coding), the UK version is the same region/version that you have. So I picked http://www.avsforum.com/avs-vb/showpost ... count=3396 , which implies that 00051 is the playlist that you want to use.
Of course the person posting that info could be wrong. :wink:
This is pretty much what I checked when I was playing the T2-Skynet Edition to select the different movie versions.
SC
Bl4ckShadow
Post by Bl4ckShadow » Mon Jan 16, 2012 5:46 am
Thanks guys for all the answers!
Finally I picked each different small title in 51.mpls and 52.mpls and muxed it to an individual .mkv to see what the difference really is.
Both of them are the introduction of the film. The difference is that in 726 the name - which is shown in an animation - is written in English and in 745 it's German. That's it^^ :)
Regards
Smithcraft
Post by Smithcraft » Mon Jan 16, 2012 10:31 am
That would be the way it appeared from the info at the AVS forum. Two files, one a few minutes, and then the other the rest of the film.
SC
freem@n
Post by freem@n » Mon Sep 03, 2012 5:23 pm
I also was surprised like Bl4ckShadow when I saw the two 'identical' titles. Luckily I found this thread. I chose the 52.mpls for the german presentation and it worked like a charm. Thank you all for posting this helpful guide, because this was my first bd-copy
made my day :)
