MKB20_v82_TGTBTU_Extended_UHD_13AC.tgz
MKB20_v82_The_Good_The_Bad_And_The_Ugly_53EC.tgz
These files are also available here : https://drive.google.com/drive/folders/ ... r1xW_sW88a
Dumps Submitted - The Good, The Bad And The Ugly (UK Arrow)
Bluntmad
keydb_helper
Re: Dumps Submitted - The Good, The Bad And The Ugly (UK Arrow)
Hey Bluntmad, thanks for providing suitable disc dump files. Both of your discs have been added to the public keydb.Bluntmad wrote: Fri Aug 01, 2025 1:42 pm MKB20_v82_TGTBTU_Extended_UHD_13AC.tgz
These files are also available here : ...
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
gentile2226
Thanks for getting to this before I could, my copy arrived early but I was busy so I'm very happy they've been added to the public keydb already! I downloaded it and can confirm it's working.
