The WH16NS60 1.02MK is the recommended firmware for your drive. But theoretically, there could be a better firmware in the future.
zittrig
Re: SDFtool Flasher
It's an option, no need. Better have and do not need than need and do not have.
Re: SDFtool Flasher
If you need / want compatibility with other rip software you can flash now to that, too. If you want to check burn quality with qpxtools you can also flash to WH16NS58 1.V5. Otherwise you should be all set.HerrNerdstrom wrote: Fri Aug 01, 2025 3:40 am I just flashed my LG WH16NS40 to DE_LG_WH16NS60_1.02_MK per instructions because the original firmware was encrypted. The instructions say that I can now flash to another firmware if I choose. Why would I want that? What are the benefits of a different firmware? The only version I could see that matches is the DE_LG_WH16NS40-NS50_1.02.
Thanks.
HerrNerdstrom
Re: SDFtool Flasher
zittrig & Coopervid -- Thanks. It seems to be working just fine now with MakeMKV, so I will stick with the MK version.
Lifelove82
Re: SDFtool Flasher
Anyone have the tar file to put in the folder so my drive can read 4k disk. Thanks.
SHIELD_AC
Re: SDFtool Flasher
I have an archgon MD-8107-U3 and I would like to rip UHD discs. My fireware is on version 1.02. I don’t have the technical experience to understand what I’m doing and I would like some reassurance that I’m not to screw something up. As I understand it, all I need is MakeMKV, the flasher, and the firmware pack. From there, all I need to do is flash the DE_LG_BU40N_1.03_MK.bin firmware, right? Am I missing anything?
Re: SDFtool Flasher
Huh??Lifelove82 wrote: Thu Aug 07, 2025 6:30 am Anyone have the tar file to put in the folder so my drive can read 4k disk. Thanks.
You have to have a Libredrive enabled drive to be able to read 4k discs. If your drive is not Libredrive enabled, it may be able to be flashed to enable it.
What drive do you have? Can you copy and paste the MakeMKV drive info and Libredrive info sections?
VulcanCCIT
Re: SDFtool Flasher
Both the 1.3.6 and the 1.3.5 versions of the Flasher will not download. I have tried both on my mac and my PC. It downloads all of the bytes, but never completes and complains about check internet connectivity. Sometimes it shows a download_repair.htm document. The version prior to that downloads just fine. I am not sure if you folks are aware, but just passing it on. Hope this helps!
Re: SDFtool Flasher
Version 1.3.6 downloaded correctly for me using Safari on a Mac after I clicked through the warning about the connection not being HTTPS.VulcanCCIT wrote: Mon Aug 18, 2025 11:24 pm Both the 1.3.6 and the 1.3.5 versions of the Flasher will not download. I have tried both on my mac and my PC. It downloads all of the bytes, but never completes and complains about check internet connectivity. Sometimes it shows a download_repair.htm document. The version prior to that downloads just fine. I am not sure if you folks are aware, but just passing it on. Hope this helps!
VulcanCCIT
Re: SDFtool Flasher
The link itself is https, but even if I edit it and make it http only it still resolves to https unless im clicking the wrong link...im clicking the one that is pinned to the the first post of this thread:dcoke22 wrote: Tue Aug 19, 2025 6:17 amVersion 1.3.6 downloaded correctly for me using Safari on a Mac after I clicked through the warning about the connection not being HTTPS.VulcanCCIT wrote: Mon Aug 18, 2025 11:24 pm Both the 1.3.6 and the 1.3.5 versions of the Flasher will not download. I have tried both on my mac and my PC. It downloads all of the bytes, but never completes and complains about check internet connectivity. Sometimes it shows a download_repair.htm document. The version prior to that downloads just fine. I am not sure if you folks are aware, but just passing it on. Hope this helps!
https://www.mediafire.com/file_premium/ ... 9.zip/file
I have tried with safari and chrome on the mac ... and with chrome on the PC
Is that the same one you are clicking?
VulcanCCIT
Re: SDFtool Flasher
It must be something on my end. I turned off Malwarebytes website monitoring and that didnt help... so I tried the link on my iphone and AT&T's active armor's internt monitoring blocked the site saying it was malicious...but I turned that off and it downloaded fine. What is odd is Active Armor is not on my Mac/PC, unless it is something Cox Cable is blocking...but its not a block as it downloads all of the bytes then just hangs there and eventually times out on the PCs...very odd.
ahmedtou
Re: SDFtool Flasher
Can this method fix my old drive HL-DT-ST BD-RE GGW-H20N with ROM version XA02?
I posted about it here:
viewtopic.php?f=8&t=39066
Help me, guys.
Help me, guys.
Re: SDFtool Flasher
No, you can't do anything with that old drive. It's too old and has the wrong drive platform.ahmedtou wrote: Wed Aug 27, 2025 8:40 am Hi,
Help me, guys.
Naiera
Re: SDFtool Flasher
I did only this and now I'm ripping an episode of Lower Decks...? Not complaining, of course
Re: SDFtool Flasher
Very doubtful as the BP50NB40 firmware is not UHD compatible. This model must be cross-flashed to enable UHD readability.Naiera wrote: Tue Sep 02, 2025 11:28 amI did only this and now I'm ripping an episode of Lower Decks...? Not complaining, of courseRipping my Joy UHD also worked, but it was a huge file, so after I've confirmed that the Star Truck episode works, I'll rip an episode of The Last of Us on UHD, and then I guess... it's done?
Again, not complaining if that's really it
Naiera
Re: SDFtool Flasher
It wasn't the model I quoted. Not sure exactly which one it was. But I did just the one thing and it ripped both BD and UHD.
