MakeMKV v1.18.1 linux(x64-release) stuck when launched
rstevenson1976
Post by rstevenson1976 » Fri Jun 06, 2025 6:37 pm
I built it from source following the instructions, I even updated the ffmpeg by following the instructions.
it launches but it's stuck at Scanning CD-ROM devices and everything is greyed out but Quit, Clear Log, and About and Purchase
EDIT: only happens when there's a disk in the drive
Debug log started at Sat Jun  7 01:41:51 2025 , written by MakeMKV v1.18.1 linux(x64-release)
001005:0000 MakeMKV v1.18.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/randall/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at *s,+4m-r">yFd&'k/Y<sa&:29393631
No  SDF v098: ASUS_BW-16D1X-U_A105_212012021114_KLCN52E2603
SDF auto v098: ASUS_BW-16D1X-U_A105_212012021114_KLCN52E2603
robinb
Re: MakeMKV v1.18.1 linux(x64-release) stuck when launched
Post by robinb » Sun Jul 13, 2025 12:11 pm
I have just had a very similar experience. I didn't build from scratch, I installed 1.18.1 from ppa:heyarje/makemkv-beta.
I have two optical drives on my Mint 22.1 desktop and I have found a bizarre workaround:-
I have one LG Blu-ray device and a DVD drive (and access to my partner's external USB connectable Samsung Blu-ray drive).
My makeMKV stalls with identical logs to yours when it is started and there is already a disc in the LG/blu-ray drive, same if I start with an empty set of drives, then insert a b.r. disk into the LG drive.
I can rip a DVD in the DVD drive. I can rip a blu-ray in the borrowed USB-connected blu-ray drive.
What I discovered, which seems very weird, is that if I launch makeMKV and first spin-up a DVD in the DVD drive, then insert the blue-ray which I want to rip into the LG drive.... it will recognise the disk in the LG drive and then continue to function normally.
This may not help you if you are stuck with one drive - sorry, but maybe you have an old drive lying around or a USB drive hanging around (blue-ray or not). Hopefully this might be a clue as to the nature of the problem.
In case this triggers any good theories on the problem, my logs:-
$ inxi -Ddxxz
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH10LS38 rev: 1.00
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
    rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
  Optical-2: /dev/sr1 vendor: ATAPI model: iHAS124 F rev: CL9P
    dev-links: N/A
On inserting a b.r. disk into the drive the UI shows: Type: Loading... Label: Please wait
OS device name: /dev/sr0
Product: BD-RE BH10LS38
Revision: 1.00
Serial number: K9CC8F94050
Firmware date: 2011-06-07 12:34:56
Bus encryption flags: 1F
Highest AACS version: 68
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.00-A2
Disc Information
Disc is being loaded
Nothing more happens. I close the app. I notice in System Manager that there is a thread railed at 100% for 'makemkvcon', so I kill that or else they build up over retries.
The makemkv log for this failed start:
Debug log started at Sun Jul 13 11:37:59 2025 , written by MakeMKV v1.18.1 linux(x64-release)
001004:0000 Debug logging enabled, log will be saved as file:///home/robin/MakeMKV_log.txt
No  SDF v098: ATAPI_iHAS124___F_CL9P_3743524807_2E8021509179
SDF id v098: ATAPI_iHAS124___F_CL9P_3743524807_2E8021509179
No  SDF v098: HL-DT-ST_BD-RE__BH10LS38_1.00_20110607123456_K9CC8F94050
SDF id v098: HL-DT-ST_BD-RE__BH10LS38_1.00_20110607123456_K9CC8F94050
SDF auto v098: HL-DT-ST_BD-RE__BH10LS38_1.00_20110607123456_K9CC8F94050
Next I try my sequence of starting the app with empty drives, inserting a DVD into the DVD drive, letting the app detect the disc, then inserting the blu-ray into the blu-ray drive, then I switch to the blue-ray drive. MakeMKV shows the spinning disk graphic, but then quickly recognises the disk in the drive. It seems to have got past the previous sticking-point:-
Revision: 1.00
Disc Information
Label: TOP_GUN_MAVERICK
Timestamp: 2022-08-25 12:36:48
Protection: AACS v68
Data capacity: 43.80 Gb
Disc type: BD-ROM
Number of layers: 2
The log for this sequence shows:
Debug log started at Sun Jul 13 11:46:57 2025 , written by MakeMKV v1.18.1 linux(x64-release)
No auto SDF v098: ATAPI_iHAS124___F_CL9P_3743524807_2E8021509179
DEBUG: Code 0 at lk,s^g,>rq4E|q#1p:29396253
DEBUG: Code 0 at Y:/BzUZD/;fW"z7T:213136746
001003:0020 DEBUG: Code 101019395 at Y:/BzUZD/;fW"z7T:121271617
001003:0020 DEBUG: Code 101019395 at %]@]BaG$'abhOh76:213130559
001003:0020 DEBUG: Code 101019395 at fPU]a<H}AGNFc7Vv\w:121263429
001003:0020 DEBUG: Code 101019395 at fPU]a<H}AGNFc7Vv\w:121262302
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'DVD+R-DL ATAPI iHAS124   F CL9P 3743524807 2E8021509179' at offset '1048576'
Application exited at Sun Jul 13 11:49:59 2025
Kernel: 6.8.0-63-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
clocksource: tsc
Desktop: Cinnamon v: 6.4.8 tk: GTK v: 3.24.41 wm: Muffin v: 6.4.1 vt: 7
dm: LightDM v: 1.30.0 Distro: Linux Mint 22.1 Xia base: Ubuntu 24.04 noble
the_randomness
Post by the_randomness » Thu Jul 31, 2025 7:59 pm
Experiencing the same on my Gentoo system with 1.18.1 using a Asus drive:
makemkvcon f -l
Found 1 drives(s)
00: dev_21:3, /dev/sr0, /dev/sr0
  ASUS_BW-16D1HT_3.11_212012011759_KLAP37I2815
SDF.bin version: 0x0098
Drive Tool SDF present
Drive Specific SDF not present
Identification SDF present
8000:LibreDrive Information
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:JB8 :ASUS    :BW-16D1HT       3.11:W000600:-
the_randomness
Post by the_randomness » Thu Jul 31, 2025 8:17 pm
I had to downgrade to 1.17.7 to escape the stuck versions.
rrubberr
Post by rrubberr » Wed Sep 03, 2025 3:37 am
Another Gentoo user here, experiencing the same with v1.18.1. Downgrading to v1.17.7 as recommended by another user fixed it for me as well.
outomaisteri
Post by outomaisteri » Thu Sep 11, 2025 6:03 pm
Linux Mint user, had issues with 1.18.1 too (Asus drive), but downgrading to 1.17.7 worked for me as well.
In case anyone else is wondering, decent instructions for downgrading in this thread: viewtopic.php?t=35897
outomaisteri
Post by outomaisteri » Fri Sep 26, 2025 10:58 pm
Seems to be issue still persists in 1.18.2. Just tried to install on a separate laptop, had to downgrade.
denser
Post by denser » Wed Oct 22, 2025 7:21 pm
I ran into the same issue on 1.18.2. I made an account on this forum to confirm that 1.17.7 indeed works for me.
I'm trying to be helpful, but I am new to this so bear with me here
nienna
Post by nienna » Wed Oct 29, 2025 1:41 pm
I can confirm that behaviour with 1.18.2 [linux(x64-release)] on openSuse Leap 15.6
Installed from pacman repository.
Occours only with blu-ray disks; DVD are recognised as expected.
I can confirm the workaround from robinb working for me as well, while the dvd drive is an internal SATA drive and the blu-ray drive is a external USB drive:
robinb wrote: Sun Jul 13, 2025 12:11 pm What I discovered, which seems very weird, is that if I launch makeMKV and first spin-up a DVD in the DVD drive, then insert the blue-ray which I want to rip into the LG drive.... it will recognise the disk in the LG drive and then continue to function normally.
