Asus BW-16D1HT with firmware 1.01 but made in dec 2023
anonymous_47389
Post by anonymous_47389 »
Hi. So I know this question about 1.01 firmware for the asus BW-16D1HT has been asked before and the answer is drives with 1.01 firmware don't support UHD and will brick if update, but It was my understanding that only old drives came with this firmware. I just bought a used drive and it says on the label "Manufactured December 2023". Is it possible this drive's hardware supports UHD bluerays and was just flashed with a really old firmware. If that's the case can I upgrade it again? Is it more likely a scam and someone just slapped a new label on an old drive? The return window closes august 1st so I'll probably just return it.
Here is the info from makemkv:
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 1.01
Serial number: K83C3E34715
Firmware date: 2113-02-05 19:30
Bus encryption flags: 1F
Highest AACS version: 68
Drive platform: MT1939
Firmware version: 1.01
BD raw metadata read: Partial
worth noting that there is a 4k UHD disk inserted when I copied this info.
Re: Asus BW-16D1HT with firmware 1.01 but made in dec 2023
anonymous_47389 wrote: Thu Jul 31, 2025 1:59 am Hi. So I know this question about 1.01 firmware for the asus BW-16D1HT has been asked before and the answer is drives with 1.01 firmware don't support UHD and will brick if update, but It was my understanding that only old drives came with this firmware. I just bought a used drive and it says on the label "Manufactured December 2023". Is it possible this drive's hardware supports UHD bluerays and was just flashed with a really old firmware. If that's the case can I upgrade it again? Is it more likely a scam and someone just slapped a new label on an old drive? The return window closes august 1st so I'll probably just return it.
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 1.01
Well, there's no way for us to tell. We would need to see photo's of the drive and it's labels to have a chance of helping you. Better to just return it.
anonymous_47389
Last edited by anonymous_47389 on Thu Jul 31, 2025 2:41 am, edited 1 time in total.
anonymous_47389 wrote: Thu Jul 31, 2025 2:32 am here is a link to the label https://ibb.co/JjcX3Xpp
Looks like the old model to me. Must have put a new sticker with a new date on it. RETURN IT!!
anonymous_47389
Your awesome! thank you.
jdigi78
Post by jdigi78 »
Since this came up on google and helped me determine the "new" drive I purchased was a refurbished old drive with fake labels (and MUCH newer manufacturing date), I thought I'd provide some more info. If you see a drive with this type of metal housing (rounded square with a circle label in the middle), it is absolutely not the original and you should stay away. I've seen LG WH16NS60 drives on ebay with this same housing as well. Its hard to believe someone put in the effort to make fake labels (even warranty stickers!) like this but here we are. The label will have a different serial number than the one reported by the drive as well, so these are definitely not officially refurbished drives.
jdigi78 wrote: Sat Dec 27, 2025 11:45 pm Since this came up on google and helped me determine the "new" drive I purchased was a refurbished old drive with fake labels (and MUCH newer manufacturing date), I thought I'd provide some more info. If you see a drive with this type of metal housing (rounded square with a circle label in the middle), it is absolutely not the original and you should stay away. I've seen LG WH16NS60 drives on ebay with this same housing as well. Its hard to believe someone put in the effort to make fake labels (even warranty stickers!) like this but here we are. The label will have a different serial number than the one reported by the drive as well, so these are definitely not officially refurbished drives.
yes this is correct except the part about the sn of the drive even regular real lg drives the sn on sticker vs the drive itself is different
