Create an ISO of an UHD Bluray on Linux
hhmkv
Post by hhmkv » Wed Jul 30, 2025 9:47 pm
Hello everyone,
I'm a newbie in the field of ripping Blurays and UHD Blurays but I'm on master level in ripping computer games.
However, I just would like to know, what is the best method for ripping Blurays and especially UHDs to an ISO image on Linux?
I bought the MakeMKV license and also a UHD friendly drive recently, but I'm not sure how to successfully create an ISO image of the disk?
I did it with dd after opening the disk with MakeMKV:
sudo dd if=/dev/sr0 of=bluray.iso bs=4M status=progress
In one case with a UHD it worked well, but unfortunately not in the other case with a normal Bluray. I was able to use the UHD disk ISO in different ways (playing the film when mounted or ripping it with MakeMKV to an MKV file), but the bluray disk did not work very well.
I got a message from MakeMKV that opening the disk failed, and so ripping took endless time. It seems the disk was dumped including the copy protection or something else.
MakeMKV is not made for creating ISO images. The only thing I found out is the backup function in MakeMKV, which puts all files in a folder including a folder named MAKEMKV. So I would have to create an ISO from these?
So the question is how to to it the best way?
Thank you very much for your help
DukeFleed
Re: Create an ISO of an UHD Bluray on Linux
Post by DukeFleed » Thu Jul 31, 2025 10:52 am
Hi.
I don't make .iso files of my ripped Blurays (I only have standard Blurays). I've only tried once, but I used imgbrun with Wine, and it worked fine.
Then extract the entire unencrypted disk to a folder, then use imgburn. Read more here: viewtopic.php?f=8&t=38708&p=178977&hili ... rn#p178977
Fond Lion
Post by Fond Lion » Fri Aug 01, 2025 10:56 am
Create a folder backup with MakeMKV first. You can then create an image (.iso) file from the folder structure. Unfortunately, "Nero 4 for Linux" seems to be the only Linux program that supports creating UDF 2.50 filesystems, which is required for Blu-ray discs. It's an old program from 2009 but still works. I have used both Nero and ImgBurn with Wine successfully, but I prefer Nero because it's a native program, it's made by a trusted German company and it includes a GUI and a CLI program.
Nero 4 is freeware since 2012. Download links can be found on this German website: https://alexhaack.de/20435902/nero-linux-4.html.
Run the GUI program "nero" first and enter the Serial number:
9M1K-0098-P3HL-PK6P-T6UA-1E5X-E557-8X41
Afterwards, you can use the GUI or the CLI program "nerocmd". If you use the GUI, you need to chose the following settings to create a UDF 2.50 image:
You can also use the following CLI command:
nerocmd --write --drive=-1,0 --bd --udf --udf-revision=2.50 --udf-partition-type=physical --data "backup_folder/*"
"nerocmd" skips all empty folder, though (I haven't found a way to change this). For example, it will not include an empty "CERTIFICATE" folder. I don't know if this could be a problem for some Blu-ray players. Use the GUI if you want to include empty folders in your image.
hhmkv
Post by hhmkv » Sat Aug 02, 2025 2:00 pm
Thank you very much for your replies.
I'm using the iso method, because it's easier for me to handle the files instead of many small files in a folder.
However when I use makemkv the backup function is greyed out. Is this function not working for all disks or setups.
This should be the right command for the command line
makemkvcon backup --decrypt disc:0 /path/to/destination --progress
Oh yes, I remember this tool nero, I also had a licence for this years ago. And the linux version was published in 2005, as far as I remember, so 20 years ago.
I installed it from the source and it works perfectly, also detects my bluray burner drive.
But it seems it was created not with large bluray discs in mind. So even when I use image writer it says the filesize of my files is too large to burn. I'm only able to change between BD25 and BD50. Not BDXL or custom size possible. My backup size would be 60,5 GiB (64.991.335.218), settings are Bluray with custom udf version 2.50.
Do I need the command line in those cases?
georgesgiralt
Post by georgesgiralt » Sun Aug 03, 2025 7:14 am
I make a lot of BluRay discs from various documents I own because of the size of them. This is what I use :
 mkisofs -udf -iso-level "3" -input-charset "utf-8" -V <Name of Disc>  -allow-limited-size -o  <Name Of ISO File>.iso   <Directory containing the data to put into the bluray>
Hope this helps.
Fond Lion
Post by Fond Lion » Tue Aug 05, 2025 11:21 am
hhmkv wrote: Sat Aug 02, 2025 2:00 pm However when I use makemkv the backup function is greyed out. Is this function not working for all disks or setups.
The backup button is only available if the disc isn't opened. Run makemkv and then click the backup button without opening the disc.
hhmkv wrote: Sat Aug 02, 2025 2:00 pm But it seems it was created not with large bluray discs in mind. So even when I use image writer it says the filesize of my files is too large to burn. I'm only able to change between BD25 and BD50. Not BDXL or custom size possible. My backup size would be 60,5 GiB (64.991.335.218), settings are Bluray with custom udf version 2.50.
Unfortunately, I don't have experience with such large images. Perhaps Nero doesn't work with them. I can create 50 GB images with Nero's image recorder, regardless of whether "BD" or "BD DL" is selected. If your version is from 2005, I would try the latest version from the download link above.
hhmkv wrote: Sat Aug 02, 2025 2:00 pm Do I need the command line in those cases?
Try it with "nerocmd" and please report back if it worked.
georgesgiralt wrote: Sun Aug 03, 2025 7:14 am Hello,
Hope this helps.
This won't create an image compliant with Blu-ray specifications, so it won't be possible to burn it back to a Blu-ray disc and play it on a hardware Blu-ray player. I guess it will work with software players like VLC, though.
georgesgiralt
Post by georgesgiralt » Wed Aug 06, 2025 6:07 pm
Ah ?
I did one from a backup BluRay and it plays fine in my Sony player attached to my TV set.
It is the first time I do this, though, so I can't comment on other discs.
Do you know what to do to make a proper BluRay disc ? I'm curious.
Fond Lion
Post by Fond Lion » Thu Aug 07, 2025 10:38 am
Standard Blu-ray discs require the UDF 2.50 filesystem. Maybe your Sony player accepts other filesystems as well.
Please see my post above about how to create UDF 2.50 discs with Nero. ImgBurn with Wine can also be used.
Rojma
Post by Rojma » Fri Aug 08, 2025 3:57 pm
There are docker images that basically run ImgBurn via Wine:
https://github.com/jlesage/docker-imgburn
https://github.com/JWolvers/imgburn-wine-container
I personally like the second one a bit more.
hhmkv
Post by hhmkv » Mon Aug 11, 2025 2:08 pm
Thank you very much for your numerous and very useful replies.
I finally got it working with ImgBurn. Nero didn’t work well with UHD. Imgburn makes the image the size it needs to have according to the filesize.
However in de first step I used it on windows. I will try to make it run on Linux. With docker or wine. I will see. Thank you very much.
georgesgiralt
Post by georgesgiralt » Mon Aug 25, 2025 5:21 pm
Hello Guys,
I've a terrible back pain so I must stay indoor and seated still.
What to do when you're in front of a computer ? You play with it.
First, I did install ImgBurn on a Virtualbox Windows 11 machine I have.
Then I made available the Linux home directory to this machine. And, after backing up one of the very few Blu Ray I own using MakeMkv, I used Imgburn to generate an ISO file.
the Linux udfinfo utility says it is "udfrev=2.50" ... So far so good.
Then I got an idea "and what will happen if I use Brasero to copy the media ?
So I went back to my trusted Ubuntu, put back my Blu Ray in the drive, opened it with VLC, then used Brasero to make an ISO image from it.
Took a while ;-) and then, udfinfo says : "udfrev=2.50"....
So I bet I'm good to go ;-)
I won't commit this ISO to a physical media to test it on my Sony player, but I'm confident it will work perfectly... As I own the Blu ray no need to burn it and hold the 38 GB iso files neither....
Have a nice day !
blucheer
Post by blucheer » Mon Aug 25, 2025 7:29 pm
hhmkv wrote: Sat Aug 02, 2025 2:00 pm Thank you very much for your replies.
I don't think MakeMKV has the save to ISO option with Blurays, only DVDs.
blucheer
Post by blucheer » Mon Aug 25, 2025 9:38 pm
Hope this helps.
This worked for me minus <Name of Disc>! I'm using EndeavourOS (an Arch flavor).
I backed up the Bluray with MakeMKV and then ran the command above to make the ISO.
Burned the ISO to disc with Brasero, and it plays perfectly in SMPLayer with my LG BH16NS40, and on my OPPO 203.
Thank you georgesgiralt :)
