Top loading vs slot loading?
Danby
Post by Danby »
Is there any difference between top loading and slot loading drives in terms of reliability and longevity?
zittrig
Re: Top loading vs slot loading?
Post by zittrig »
Top Loading is imo more prone to defects.
The hilt with the connected technique is the weak point.
Danby wrote: Wed Jul 30, 2025 6:45 am Is there any difference between top loading and slot loading drives in terms of reliability and longevity?
Personally, I will never buy a slot load. They are prone to issues with the disc in/out mechanism. Top loading are fine. Never had an issue. Same with the normal tray loading drives.
