Asus BW-16D1HT MT939
bkvaluemeal
Post by bkvaluemeal »
Hi all, I have an Asus BW-16D1HT that I purchased circa 2013 and am wanting to rip UHD content. It shipped with the MT939 platform which is different from the MT959 platform I've seen elsewhere on the forum. The latest version of Marty's SDF GUI tool correctly blocked me from flashing the 3.10 MK firmware due to this mismatch, but I thought it would still work and instead used an older version of the software to bypass the protection. I fear I have bricked the device, because now the drive lists itself as "revision: BOOT". I did however dump the original firmware before flashing. Is there a way to recover my drive and/or patch it with MK firmware to enable UHD content? I'm a fairly technical engineer and have some repair equipment, but not the knowledge of how to use it -- feel free to suggest hands on tasks.
zittrig
Re: Asus BW-16D1HT MT939
Post by zittrig »
Look there at the top of the first post under the fat red subheading --> viewtopic.php?f=16&t=19634
The blocked process of the SDF flasher should have been good advice for you.....
It's bricked. Use the DOS flash way or buy a new one.
tbrady3742@aol.com
Post by tbrady3742@aol.com »
bkvaluemeal wrote: Mon Jul 14, 2025 1:33 pm Hi all, I have an Asus BW-16D1HT that I purchased circa 2013 and am wanting to rip UHD content. It shipped with the MT939 platform which is different from the MT959 platform I've seen elsewhere on the forum. The latest version of Marty's SDF GUI tool correctly blocked me from flashing the 3.10 MK firmware due to this mismatch, but I thought it would still work and instead used an older version of the software to bypass the protection. I fear I have bricked the device, because now the drive lists itself as "revision: BOOT". I did however dump the original firmware before flashing. Is there a way to recover my drive and/or patch it with MK firmware to enable UHD content? I'm a fairly technical engineer and have some repair equipment, but not the knowledge of how to use it -- feel free to suggest hands on tasks.
I have the ASUS BW-16D1HT also but after I upgraded makeMKV to version 18, I keep getting OS and Scsi errors. Works fine on dvdFAB but takes forever to download. Are you having any trouble copying movies after the upgrade?
tbrady3742@aol.com wrote: Tue Jul 29, 2025 8:03 pm
Revert back to an older version of MakeMKV and see if that fixes it.
tbrady3742@aol.com
MartyMcNuts wrote: Wed Jul 30, 2025 12:21 am
Where can I find an older version?
tbrady3742@aol.com wrote: Wed Jul 30, 2025 12:32 am Where can I find an older version?
https://makemkv.com/download/old/
