Running Ubuntu 24.0.2 Using
ARM 2.13.0
MakeMKV 1.18.1
I had been using system for some time with previous beta version of MakeMKV. Not sure what version but it was 4 months ago that I installed it. Ran through 130 DVDs and Blu-ray disks, successfully.
Took a couple of weeks off and next time I ran it, I got an error saying my beta key had expired. So, I downloaded 1.18.1 bin and oss. Both installed successfully. Next time I ran I got error. Syslog below.
[06-25-2025 21:42:33] INFO ARM: ************* Ripping disc with MakeMKV *************
[06-25-2025 21:42:33] INFO ARM: Job running in auto mode
[06-25-2025 21:42:33] INFO ARM: Updating MakeMKV key...
MakeMKV beta key for this month: T-iyhMMBV8nWtNo3BgMdcvypH8UL01nYmww2zFzQDtiZsdJUOaAuCURsPRQ1Hj3i75RE
/home/arm/.MakeMKV/settings.conf exists, updating value of app_Key
[06-25-2025 21:42:34] INFO ARM: Starting MakeMKV rip. Method is mkv
[06-25-2025 21:42:34] ERROR ARM: Call to MakeMKV failed with code: 1 (b'')
[06-25-2025 21:42:34] ERROR ARM: MakeMKV did not complete successfully. Exiting ARM! Error: exceptions must derive from BaseException
I don't think I can go back to previous version, since beta key is too old?
I have been working with ARM forum, and it doesn't seem to be a problem with ARM.
Thanks, John
version 1.18.1 MakeMKV failed code: 1(b ')
johnmartin4
MegaPixel
Re: version 1.18.1 MakeMKV failed code: 1(b ')
Having the exact same issue but my ARM is running 1.17.9, Yesterday was using ARM no problem until Makemkv suddenly decided to stop in between jobs. was unable to update to 1.18.1, but I'm willing to accept user error on that
[07-14-2025 20:51:20] INFO ARM: ************* Ripping disc with MakeMKV *************
[07-14-2025 20:51:21] INFO ARM: Job running in auto mode
[07-14-2025 20:51:21] INFO ARM: Updating MakeMKV key...
[07-14-2025 20:51:22] INFO ARM: Starting MakeMKV rip. Method is mkv
[07-14-2025 20:51:22] ERROR ARM: Call to MakeMKV failed with code: 1 (b'')
[07-14-2025 20:51:22] ERROR ARM: MakeMKV did not complete successfully. Exiting ARM! Error: exceptions must derive from BaseException
Traceback (most recent call last):
File "/opt/arm/arm/ripper/makemkv.py", line 52, in makemkv
mdisc = subprocess.check_output(
File "/usr/lib/python3.10/subprocess.py", line 421, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/lib/python3.10/subprocess.py", line 526, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command 'makemkvcon -r info disc:9999 | grep /dev/sr0 | grep -oP '(?<=:).*?(?=,)'' returned non-zero exit status 1.
MegaPixel
Posting because i seem to have resolved the issue, or at least the ARM devs did.
Needed to pull the latest version of ARM, In my case: "docker pull automaticrippingmachine/automatic-ripping-machine"
Then rebuild the container.
After that i was able to rip discs again.
Found the issue was raised directly here: https://github.com/automatic-ripping-ma ... ssues/1432
Hope that helps
Hope that helps
johnmartin4
The post you found on ARM forum was mine. I started there.
I am not ready to give up and upgrade ARM. Anybody form MakeMKV support group got a thought?
johnmartin4
Nobody seems to have any ideas.
Is there a non beta version I can try before purchasing a key?
Want to get this working again.
Never got any ideas, so I decided to update Automatic Ripping Machine (ARM).
I clicked on the "Update Available" link and let it update.
Then put in a DVD and let it run. It did not run long before system crashed. On reboot, Ubuntu got a kernel panic and would not start. I tried recovery options, but no luck. So I reinstalled Ubuntu, Docker and ARM. Fortunately my config files were all on another file system so Arm started back up okay. I then put in DVD, and everything is working again. I have processed several DVDs and all seems to be working again.
A bit brute force, but it is working again.
Thanks for the help. and I'll close cases.
