Pioneer BDR-XD08B
Re: Pioneer BDR-XD08B
Could someone please share this ephemeral private message publicly? Thanks, folks.
Good morning! Had a good sleep? Check for Billycar11 and write an email to him.uluhh wrote: Tue Jul 29, 2025 8:09 pm Could someone please share this ephemeral private message publicly? Thanks, folks.
sandersoni
Does the announcement, that all Poineer drives are now LibreDrive supported mean that even post Nov-2022 firmware drives can now be crossflashed? viewtopic.php?t=37848
Looking to buy a recent model of these for 4K discs.
No. Support for those is still coming...sandersoni wrote: Sat Aug 23, 2025 2:33 am Does the announcement, that all Poineer drives are now LibreDrive supported mean that even post Nov-2022 firmware drives can now be crossflashed? viewtopic.php?t=37848
Theprofessor
This is my drive can it be made to paly 4k discs
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.02
Serial number:
Firmware date: 2022-12-27
Drive platform: Pioneer RS9330
Firmware version: GENE
OS device name: F:
Revision: 1.02
Serial number:
You gotta wait. Firmware is too new.Theprofessor wrote: Mon Sep 01, 2025 12:05 pm This is my drive can it be made to paly 4k discs
OS device name: F:
Revision: 1.02
Serial number:
if you want it to work now email me i have some experimental flasher i made would be significantly more than $25Theprofessor wrote: Mon Sep 01, 2025 12:05 pm This is my drive can it be made to paly 4k discs
OS device name: F:
Revision: 1.02
Serial number:
as i need to remote in to do it
email me for details
Theprofessor
Hi billy , i am an electronics engineer, i would appreiacte if you could send me the details and fw ,i can upload teardown images to help further manual mods ?
Will not be making this method publicTheprofessor wrote: Tue Sep 02, 2025 7:10 pm Hi billy , i am an electronics engineer, i would appreiacte if you could send me the details and fw ,i can upload teardown images to help further manual mods ?
No disassembly is required.
For details email me
Theprofessor
hi billy are you going to give it me for free using as soic clip the firmware can be reflashed quick with updated code
Hye, as my previous pioneer burner is out of order, i just buy a new BD-RW BDR-XD08, but this last is not libreDrive, of course.
Maybe Coopervid could help me (or someone else) with the good flasher and firmware
Thanks in advance
Informations lecteur
Nom du lecteur SE : E:
Fabricant : PIONEER
Produit : BD-RW BDR-XD08
Révision : 1.02
Numéro de série : DIDL013359UC
Date micrologiciel : 2022-12-27
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 82
EDIT: so the firmware is too recent, i'll waiting.
Thanks in advance
Fabricant : PIONEER
Révision : 1.02
I can help you if you want but be aware it is experimental and has some downside that will be fixed later in the email I will tell you the downsides see email belowtt1270 wrote: Wed Sep 17, 2025 5:07 pm Hye, as my previous pioneer burner is out of order, i just buy a new BD-RW BDR-XD08, but this last is not libreDrive, of course.
Thanks in advance
Fabricant : PIONEER
Révision : 1.02
thank you Billy, email sent.
subzero1155
I *thought* I had gotten lucky and randomly found this drive brand new at an overstock warehouse type of place, but alas the firmware is 1.02.
However, it sounds like some effort and progress is being made to get these drives with this problematic firmware able to read/rip UHD discs? I can wait to do it, but am just wondering if I should hold onto this drive or go ahead and return it while I can since I am trying to stockpile a few drives for this specific purpose. It seems I fell asleep at the wheel the last couple of months and missed the news about all PC optical drives no longer being manufactured. I knew it was coming, but was hoping it wasn't going to happen as soon as it did
Thank you for any direction on this.
