Asus BW-16D1X-U
Andy_01
Asus BW-16D1X-U
#1 Post by Andy_01 » Tue Jul 29, 2025 3:41 pm
Hi, can anyone please help. Is this drive able to be patched to read 4K?
If so could you please advise what flash utility to use and which firmware?
Thank you!
Andy
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number:
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
Re: Asus BW-16D1X-U
#2 Post by Billycar11 » Tue Jul 29, 2025 5:04 pm
See guide below or email me or Marty for an automated flasher
Andy_01
Re: Asus BW-16D1X-U
#3 Post by Andy_01 » Tue Jul 29, 2025 5:57 pm
Thank you! As it turns out I took a chance and used the SDFTool Flasher v1.36 and Firmware WH16NS60-1.02
Worked like a charm.
oap1ikwydlsh2o
Re: Asus BW-16D1X-U
#4 Post by oap1ikwydlsh2o » Mon Feb 23, 2026 7:43 pm
hi , which software di u use please
OneDay
Re: Asus BW-16D1X-U
#5 Post by OneDay » Mon Mar 02, 2026 8:12 am
I used SDFTool 1.36
Used Firmware BW-16D1HT 3.10
Worked perfectly since it is a Asus drive.
oap1ikwydlsh2o
Re: Asus BW-16D1X-U
#6 Post by oap1ikwydlsh2o » Mon Mar 02, 2026 9:50 am
thank you , worked forst time .
zittrig
Re: Asus BW-16D1X-U
#7 Post by zittrig » Mon Mar 02, 2026 11:06 am
OneDay wrote: Mon Mar 02, 2026 8:12 am I used SDFTool 1.36
To avoid the Sleep Bug or have less problems with 3-Layer discs feel free to flash to LG WH16NS60 1.02MK.
OneDay
Re: Asus BW-16D1X-U
#8 Post by OneDay » Thu Mar 05, 2026 7:31 am
oap1ikwydlsh2o wrote: Mon Mar 02, 2026 9:50 am thank you , worked forst time .
Glade it worked
Also as zittrig said flash the LG WH16NS60 1.02MK
The drives in the BW-16D1X-U are rebranded LG WH16NS40 from what I have researched.
