Can't find a USB Buffalo External BR Reader/Burner
djfnec2005
Post by djfnec2005 » Mon Oct 19, 2009 9:23 pm
I have installed the MakeMKV program but it can't find my usb bluray drive. Any thoughts on what I can do to get it to detect? It's a USB Buffalo external player. I can rip the files to my hard drive with anydvd and then convert them with Make MKV but I can't rip them right to MKV. Any help would be appreciated. Thanks
Re: Can't find a USB Buffalo External BR Reader/Burner
Post by mike admin » Sat Oct 31, 2009 9:55 am
can you please enable "log debug messages" in preferences, restart the program and post the log here? This will help to troubleshoot the problem.
djfnec2005
Post by djfnec2005 » Tue Nov 03, 2009 3:47 am
This is without the drive plugged in. If you need it with the drive plugged in and turned on let me know.
MakeMKV v1.4.8 beta win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Dave/MakeMKV_log.txt
FAILURE: Code 3221225488 at `O>x,Je3*7/w%s:213130927
FAILURE: Code 3221225488 at dSxz^+8VEkv' -.':121263061
FAILURE: Code 0 at dSxz^+8VEkv' -.':121262762
FAILURE: Code 0 at 4sa,n4KrKusRVFPXBpq1+:2CTF:29393516
The program can't find any usable optical drives.
Post by mike admin » Tue Nov 03, 2009 10:02 am
yes please, also try it with the drive. Also, what OS are you using?
djfnec2005
Post by djfnec2005 » Fri Nov 06, 2009 3:13 pm
No Problem, I will post the new log data with the drive plugged in and turned on when I get home tonight. The OS is Windows Vista Home Premium 64 bit on a HP Pavilion dv7-1285dx laptop, 2.4GHz Intel Core 2 Duo P8600, 6GB 800MHz DDR2, Mobile Intel PM45 Express Chipset, USB 2.0. Let me know what other info you might need.
djfnec2005
Post by djfnec2005 » Sat Nov 07, 2009 11:17 pm
Here is the log data with the drive plugged in and turned on
djfnec2005
Post by djfnec2005 » Mon Nov 16, 2009 6:31 pm
Has anyone used an external usb drive successfully with this software? I'm thinking of possibly getting a different drive to attach to my laptop.
