MakeMKV above v1.17.7 still broken on Linux
visionviper
Re: MakeMKV above v1.17.7 still broken on Linux
Post by visionviper » Thu Jul 17, 2025 12:03 am
I'd like to hear more about what people are doing for build/install. I had zero issues with v1.18.1 following the official instructions. But I see people making reference to Flatpak and a tar file I never downloaded or used.
Is someone willing to post a detailed step by step of what they are doing?
iktas_
Post by iktas_ » Mon Jul 28, 2025 3:33 am
I'm also having the same problem. No fixes as of now. I'm on NixOS Warbler, installed makemkv through nixpkgs version 1.18.1. All the same problem as you guys have mentioned but unfortunately none of the fixes are working. Adding DVD first doesn't work, replacing _private_data.tar doesn't work. Downgrading just crashes the makemkv instance. I'm stuck right now :(
SamSpeexy
Post by SamSpeexy » Tue Aug 05, 2025 1:53 pm
I believe the problem might have something to do with MakeMKV attempting to dump drive firmware. One of my drives that doesn't work with 1.18.1 is an older model flashed with firmware from a long time ago. When using MakeMKV 1.17.7 offline, it successfully dumps the firmware to the .MakeMKV settings folder as a .tgz file. When I upgrade to 1.18.1, and use it offline, it works fine with the older drive as long as the .tgz file is in the .MakeMKV settings folder. Two of my newer libredrives don't have any issues with 1.18.1 at all. Both have factory firmware.
I hope this helps.
Miramur
Post by Miramur » Sat Aug 30, 2025 4:05 pm
@SamSpeexy +1.
This worked for me. 1.17.7 offline, dump firmware tgz, then all versions past and current worked. Thank you!
helvetichris
Post by helvetichris » Sat Aug 30, 2025 4:27 pm
I'm a total noob but i found this old and very easy solution which works perfectly for me on CachyOS with the latest version of Makemkv
Create a file on /etc/modules-load.d/ with the content sg then reboot. Mine is named sg.conf but the name is totally arbitrary.
Post is here : https://www.reddit.com/r/makemkv/commen ... ny_usable/
I hope it helps
matthewvinton
Post by matthewvinton » Thu Sep 04, 2025 11:21 pm
The dump_FW_*.tgz firmware dump file was absolutely the issue I had as well. My drive is USB (BDR-XS07S), and I had access to a Mac. I hooked it up and it immediately told me it created the file in ~/Library/MakeMKV. I copied it into ~/.MakeMKV on my Linux system and it started to be able to access discs. Thanks for the guidance!
BuffaloSlack
Post by BuffaloSlack » Fri Sep 12, 2025 2:20 am
Same issue, new user.
No issues with 1.18.1 on Debian compiled from source with a DVD only drive, ripped some DVDs fine.
However my blueray drive, a Buffalo media station external can not load DVDs or blurays just endless spin and I can see makemkvcon processes are stuck at 100% unresponsive
On 1.17.7 complied from source no issues, rips blu rays fine. I also noticed 1.18.1 not creating the FW dump so I tried copying it from 1.17.7 to the .MakeMKV folder but that didn't help me like it did others.
Still trying to figure this out.
BuffaloSlack
Post by BuffaloSlack » Mon Sep 15, 2025 6:09 pm
So an update, try as I might I cannot get > 1.17.7 going on Linux with a bluray drive; endless scanning... tried every permutation I could think of. Just as an addendum here is the drive information:
OS device name: /dev/sr0
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN14
Firmware date: 2121-06-21 13:33
Bus encryption flags: 1F
Highest AACS version: 16
I've yet to try hooking up both a DVD and BD drive at the same time and loading a DVD first workout that's next.
BuffaloSlack
Post by BuffaloSlack » Tue Sep 16, 2025 5:18 pm
So after going through the forum trying to find a solution there are more than half a dozen topics that relate to this issue (couple on reddit too)... perhaps it would be helpful to sticky a topic where people could report problematic and working drives for > 1.17.7 on Linux?
These are just the topics relating to this endless scanning issue just on the first page of the forum (not including this one) - might be helpful for future people encountering this issue and wanting to buy a new drive that works > 1.17.7:
SamSpeexy
Post by SamSpeexy » Sat Sep 20, 2025 8:50 am
BuffaloSlack wrote: Mon Sep 15, 2025 6:09 pm So an update, try as I might I cannot get > 1.17.7 going on Linux with a bluray drive; endless scanning... tried every permutation I could think of. Just as an addendum here is the drive information:
Revision: BN14
For whatever the reason, 1.18.1 seems to prefer libredrives over non-libre drives.
I believe your drive and firmware are the same as the poster in this link.
viewtopic.php?p=178868#p178868
Your drive platform (MT1959) is capable of supporting Libredrive with the correct firmware. In your case, the drive appears to be similar to the LG BU40N and has encrypted firmware (BN14).
If you're willing to take the risk, reinstall Makemkv 1.17.7 and flash the BU40N 1.03MK firmware to your drive by carefully following the Ultimate UHD Drives Flashing Guide viewtopic.php?f=16&t=19634
16442496
Post by 16442496 » Sat Sep 20, 2025 5:28 pm
I have two old Pioneer BD-ROM drives from year 2008.
Firmware dump problem here too.
MakeMKV 1.17.6 works very well and i get that Firmware dump.
So here is what i do:
First i compile/install MakeMKV 1.18.1 from source.
Then i run 1.17.6.appImage to get firmware dump.
After that both drives works with 1.18.1.
Link to MakeMKV AppImage:
https://github.com/uncle-ben-devel/make ... tag/1.17.6
Debian
MakeMKV 1.17.6 (Registered)
flojo
Post by flojo » Sat Sep 20, 2025 10:39 pm
16442496 wrote: Sat Sep 20, 2025 5:28 pm First i compile/install MakeMKV 1.18.1 from source.
Appimage? You should only need the single file binary "makemkvcon" from 1.17.6, https://makemkv.com/download/old/makemk ... 7.6.tar.gz
BuffaloSlack
Post by BuffaloSlack » Sat Sep 20, 2025 11:04 pm
SamSpeexy wrote: Sat Sep 20, 2025 8:50 am For whatever the reason, 1.18.1 seems to prefer libredrives over non-libre drives.
Thanks for this tip, yeah its the ‎BRXL-PUS6U3B and indeed according to forum posts it seems the BU40N 1.03MK firmware is the one to flash, need to work out which specific file in the firmware pack but it's something to try.
Guess I'll have to flash it... guide mentions having to downgrade encrypted firmwares first with BU40N's so gotta look into it more.
BuffaloSlack
Post by BuffaloSlack » Sun Sep 21, 2025 1:44 am
SamSpeexy wrote: Sat Sep 20, 2025 8:50 am ..
Thanks again for the tip, successfully flashed the drive now 1.18.1 scans and rips fine on Linux.
Revision: 1.03
Highest AACS version: 19
Firmware version: 1.03
So for those who have a libredrive compatible device that's an option to fix this issue.
16442496
Post by 16442496 » Sun Sep 21, 2025 5:05 am
flojo wrote: Sat Sep 20, 2025 10:39 pm
Or i could use that 1.17.6-appImage and not compile nothing to safe time.
Debian
