Asus BW-16D1X-U Platform RS8600 Firmware Flashing?
Re: Asus BW-16D1X-U Platform RS8600 Firmware Flashing?
#31 Post by Coopervid » Wed Jul 09, 2025 4:10 pm
HSamwel wrote: Wed Jul 09, 2025 10:11 am
Coopervid wrote: Wed Jul 09, 2025 9:30 am
HSamwel wrote: Tue Jul 08, 2025 9:46 pm
Hi!
I just got the same ASUS external bluray writer and exactly the same drive information. Except OS device name: D
When I open the flash tool it says I'm not a MT1959 platform and I'm encrypted.
Could you please help me.
You need to post your Makemkv info to play it safe.
Thought I did. I'm not familiar with this forum. It cut away all quotes except your last. :lol:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ------------
Firmware date: 2020-07-21
Firmware version: ID76
PM sent.
HSamwel
#32 Post by HSamwel » Thu Jul 10, 2025 9:05 am
Worked fine. Thanks!
Did a test rip of my Jurassic World: Dominion 4k disc.
Took about 1 hour 15 minutes. MakeMKV said it reached about 4x reading speed.
This was e selected files rip of about 76GB.
Don't know if this is good or bad?!
Problem is that my laptop has two graphics cards built in. The Nvidia part is only
active with the external displays. So I'm not sure I get any hardware accelleration.
#33 Post by Coopervid » Thu Jul 10, 2025 2:38 pm
HSamwel wrote: Thu Jul 10, 2025 9:05 am Worked fine. Thanks!
All Pioneers are limited to 4x rip speed for UHDs.
Finalheaven
#34 Post by Finalheaven » Thu Jul 10, 2025 2:49 pm
Hi i have the same issue thanks in advance.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DGDL115830WL
#35 Post by Coopervid » Thu Jul 10, 2025 5:16 pm
Finalheaven wrote: Thu Jul 10, 2025 2:49 pm Hi i have the same issue thanks in advance.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM sent.
Dams1276
#36 Post by Dams1276 » Wed Jul 23, 2025 10:40 pm
Looking for information to flash my drive to support UHD
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: -------------
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 81
#37 Post by Billycar11 » Thu Jul 24, 2025 3:08 am
Dams1276 wrote: Wed Jul 23, 2025 10:40 pm Looking for information to flash my drive to support UHD
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
see guide below or email me or marty for an autoflasher
ZachMach10
#38 Post by ZachMach10 » Sun Jul 27, 2025 6:47 pm
Was curious if it is possible to access 4k movies with this device?
Any Help would be great!
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number:
Firmware date: 2018-01-15
Highest AACS version: 68
Drive platform: RS8600
Firmware version: E102/ID76
#39 Post by Coopervid » Tue Jul 29, 2025 10:45 am
ZachMach10 wrote: Sun Jul 27, 2025 6:47 pm Was curious if it is possible to access 4k movies with this device?
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number:
PM sent.
ZachMach10
#40 Post by ZachMach10 » Wed Jul 30, 2025 6:14 pm
Coopervid wrote: Tue Jul 29, 2025 10:45 am
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number:
PM sent.
TYvm
geff95
#41 Post by geff95 » Fri Aug 01, 2025 4:58 pm
Hi, I recently get a ASUS drive with the following information. If someone can help me. Thx a lot
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
#42 Post by Billycar11 » Sat Aug 02, 2025 3:36 am
geff95 wrote: Fri Aug 01, 2025 4:58 pm Hi, I recently get a ASUS drive with the following information. If someone can help me. Thx a lot
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
yes just email me that info see below
Aquahutch
#43 Post by Aquahutch » Fri Aug 08, 2025 12:39 am
Hi, can I get some guidance on whether or not it's possible to get this sucker UHD friendly?
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: ...
Firmware date: 2017-12-21
Highest AACS version: 76
Drive platform: RS8601
Firmware version: E111/ID76
Thank you!
#44 Post by Coopervid » Fri Aug 08, 2025 8:57 am
Aquahutch wrote: Fri Aug 08, 2025 12:39 am Hi, can I get some guidance on whether or not it's possible to get this sucker UHD friendly?
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: ...
Thank you!
PM sent.
Aquahutch
#45 Post by Aquahutch » Sat Aug 09, 2025 1:33 am
Coopervid wrote: Fri Aug 08, 2025 8:57 am
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: ...
Thank you!
PM sent.
You rock! Tyvm!
