Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
grimrod42
Hello
Couple weeks ago I tried to flash a Buffalo BRXL-PUS6U3B-US, I confirmed it had the LG core (if I recall correctly - either way I confirmed it was one that could be upgraded. I followed the instructions here and it looked like it was successful.
In the end though nothing happened and the firmware stayed the same. Drive still works no problem.
I wonder why it didn't work, any help would be appreciated.
Probably didn't do enc or did to low of a fe version first email me or Marty if you want an automated flasher that does it all for yougrimrod42 wrote: Sat Jul 26, 2025 1:26 pm Hello
grimrod42
Thanks, I think you are right, I don't exactly recall, but I don't think I did the enc command.
How do I determine the firmware version it has?
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN14
Serial number: MOBMC6A5827
Firmware date: 2121-06-21 13:33
Bus encryption flags: 1F
Highest AACS version: 68
I think I can manage the upgrade; therefore, I will let you know.
Revision: BN14
grimrod42
Hi. might have been missed in my last post
I was just curious how do I see what the current version of the firmware is? Doesn't seem clear from the makrmkv info.
Thank you in advance
BN14grimrod42 wrote: Sat Jul 26, 2025 3:06 pm Thanks, I think you are right, I don't exactly recall, but I don't think I did the enc command.
Revision: BN14
It equivalent of 1.04 bu40n
Darklord
I hope this message finds you well.
Unfortunately, I mistakenly flashed my **ASUS BW‑16D1HT drive to firmware 3.10MK, thinking it would enable UHD compatibility. Now it fails with 0x82052400 when I try to flash via SATA.
I understand from the community (e.g. your guide in the "Ultimate UHD Drives Flashing Guide") that I actually need to downgrade to firmware 3.02 to regain LibreDrive support.
Could you please assist me with:
1. A compatible UART-Flasher tool (flasher_uart.exe or devrecovery_uart.exe)
2. Advice on downgrading via UART (steps or timing)
I’m prepared to use my DSD Tech SH‑U09C adapter and follow the correct wiring and terminal steps.
Thank you so much for your help—this is purely for personal backup of UHD discs I own.
Best regards,
Michael
Best regards,
Michael
what does your drive info look like now?Darklord wrote: Sun Jul 27, 2025 6:09 pm Hi,
Best regards,
Michael
AffSeda
I've got an external slim LG drive that I thought was successfully flashed, but won't read any UHD.
This is where I've gotten it:
CD/DVD/BD all work fine, UHD doesn't.
I'm assuming I've either missed a step or haven't got the right firmware?
LG BP50NB40
SVC NB52 / 2024-11-29
Shipped with 1.03CD/DVD/BD all work fine, UHD doesn't.
OS device name: /dev/sr0
Product: BD-RE BP50NB40
Revision: 1.03
Highest AACS version: 76
Firmware version: 1.03
Unrestricted read speed: Yes-
see nb52 section its a 3 step processAffSeda wrote: Mon Jul 28, 2025 5:11 am I've got an external slim LG drive that I thought was successfully flashed, but won't read any UHD.
This is where I've gotten it:Code: Select all
LG BP50NB40 SVC NB52 / 2024-11-29 Shipped with 1.03
I'm assuming I've either missed a step or haven't got the right firmware?Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: HL-DT-ST Product: BD-RE BP50NB40 Revision: 1.03 Firmware date: 2120-05-07 09:17 Bus encryption flags: 17 Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Patched (microcode access re-enabled) Firmware version: 1.03 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
or email me or marty for a auto flasher if your on windows
Yeah, you've only done half the job. You need to do the cross-flash part now. Use the recovery method of SDFtool Flasher.AffSeda wrote: Mon Jul 28, 2025 5:11 am I've got an external slim LG drive that I thought was successfully flashed, but won't read any UHD.
AffSeda
I tried that but must have missed something, I've hired Billy above, so I guess he'll come to my rescue with an e-mail soon.MartyMcNuts wrote: Mon Jul 28, 2025 7:37 amYeah, you've only done half the job. You need to do the cross-flash part now. Use the recovery method of SDFtool Flasher.AffSeda wrote: Mon Jul 28, 2025 5:11 am I've got an external slim LG drive that I thought was successfully flashed, but won't read any UHD.
just sent everything all over you should be all setAffSeda wrote: Mon Jul 28, 2025 7:55 am
AffSeda
Confirmed, it works!
Darklord
Thanks for your response!
Here is the current drive information from MakeMKV:
Drive Information:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KL8K9OG0037
Firmware date: 2019-01-04 10:14
LibreDrive Information:
Hardware support: Yes
Firmware support: No
Firmware version: 3.10
No disc inserted.
I accidentally flashed the 3.10 firmware and would like to downgrade to 3.02 (or LibreDrive-compatible version) via UART. I have a DSD TECH SH-U09C adapter and I'm ready to follow the correct flashing steps.
Thanks again for your help!
Drive Information:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
No disc inserted.
No need your overthinking it.Darklord wrote: Mon Jul 28, 2025 11:45 am Thanks for your response!
Drive Information:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
No disc inserted.
Just follow the guide right here or email me or Marty for a automated downgrade flasher
