Thought that I would post this, if anyone else is having an issue with the just purchased Season 3 of the series "The Chosen".
Disc 2 in the set has and issue with title_t00. At time code 00:09:32, the problem appears to be a sync and file corruption issue with the particular title_t00. This is the second factory fresh disc, I have had the exact same issue in the exact same spot. I'm thinking that the original glass source master must have a problem, being that two discs in a row exhibit the same issue in the exact same spot.
I finally broke out and old blu-ray drive I have instead of using my new ASUS drives, (that could not finish) that can read 4K and it was able to rip the disc, with a lot of working around the problem area. Here is my log from that rip. Once it finished, at the timecode pointed out above, there is a hesitation in the video as well as the video itself is distorted for about 3 seconds and then it plays on as normal.
MAKE MKV LOG:
MakeMKV v1.17.3 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WH14NS40 1.04 KLZK15F3516d" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH14NS40 1.00 SIK9HFATE263d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=F17C89187AE0)
File 00002.mpls was added as title #0
File 00004.mpls was added as title #1
File 00003.mpls was added as title #2
Title #00007.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/Work/Tivo/Blu-ray Rips using profile 'FLAC' from file '/Applications/MakeMKV.app/Contents/MacOS/../Resources/appdata.tar:flac.mmcp.xml'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '2196897792'
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2197223424, attempting to work around
Hash check failed for file 00000.m2ts at offset 2197284864, file is corrupt.
Hash check failed for file 00000.m2ts at offset 2197481472, file is corrupt.
Hash check failed for file 00000.m2ts at offset 2197678080, file is corrupt.
Hash check failed for file 00000.m2ts at offset 2197874688, file is corrupt.
Hash check failed for file 00000.m2ts at offset 2198071296, file is corrupt.
Too many hash check errors in file 00000.m2ts.
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2206660608, attempting to work around
AV synchronization issues were found in file '/Volumes/Work/Tivo/Blu-ray Rips/title_t00.mkv' (title #1)
AV sync issue in stream 1,2 at 0:09:32.192 with duration of 2080ms : audio gap - 65 missing frame(s)
AV sync issue in stream 0 at 0:09:32.697 : video frame timecode differs by +2001.997ms
AV sync issue in stream 0 at 0:09:32.947 : video frame timecode differs by +1793.458ms
AV sync issue in stream 0 at 0:58:53.363 : video stream has 2 frames with invalid timecodes
AV sync issue in stream 4 at 0:00:00 : Forced subtitles track #4 turned out to be empty and was removed from output file
Encountered 6 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Encountered 49 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
1 titles saved
The Chosen Season 3, Disc 2 errors
Mac Studio M3 Ultra
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
Re: The Chosen Season 3, Disc 2 errors
I'm having problems with The Chosen Season 5 disc 2 trying to rip episode 4 & 6
this is what i get
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '9852942336'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '9852942336'
Failed to save title 0 to file D:/Movies/The Chosen- S05E06- Reunions (2025).mkv
Encountered 21 errors of type 'Read Error'
any ideas?
this is what i get
any ideas?
Clean the disc.MikeC1970 wrote: ↑Sun Jul 13, 2025 6:19 pmI'm having problems with The Chosen Season 5 disc 2 trying to rip episode 4 & 6
this is what i get
any ideas?
Disk is brand new never been used and has no scratches on it that i can see.MartyMcNuts wrote: ↑Mon Jul 14, 2025 3:24 amClean the disc.MikeC1970 wrote: ↑Sun Jul 13, 2025 6:19 pmI'm having problems with The Chosen Season 5 disc 2 trying to rip episode 4 & 6
this is what i get
any ideas?
None of that is relevant! The drive is having trouble reading a section of the disc. CLEAN IT! Then try again. You have nothing to lose. Another thing you could try is to clean the drive's lasers.MikeC1970 wrote: ↑Fri Jul 25, 2025 6:28 pmDisk is brand new never been used and has no scratches on it that i can see.MartyMcNuts wrote: ↑Mon Jul 14, 2025 3:24 amClean the disc.MikeC1970 wrote: ↑Sun Jul 13, 2025 6:19 pmI'm having problems with The Chosen Season 5 disc 2 trying to rip episode 4 & 6
this is what i get
any ideas?
If that still doesn't help, you may need to try a different drive. As silly as it sounds, some drives just don't like some discs. This is why most of us have multiple drives. If a disc won't read in one drive, it will most likely read in one of the other drives.
OK I’ll give that another shot and I’m also going to buy another external writer, probably that LG you have on your site. It’s gotta be the drive cause I’ve cleaned the disk and even shot some compressed air in the drive and still nothing. It’s gotta be the drive like you said or the disk is faulty to begin with. If I get it to work with another drive I’ll post back here to let you know. Thanks for the help!
