https://www.dropbox.com/scl/fi/78m4w800 ... f9o1r&dl=0
Will not decrypt.
Flight Risk nordic
keydb_helper
Re: Flight Risk nordic
Hey HSamwel, the 65CE variant of Flight Risk has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
HSamwel
Thanks! Tested and it will decrypt now.
Yes, I have KEYDB.cfg and the helper app installed already, Did an update just before
testing this disk yesterday.
You'll want to use the synchronize function periodically as keys are added constantly.
