Hello, I’m having trouble backing up the Japanese Blu-ray disc 薬屋のひとりごと 第2期 2巻 (Kusuriya no Hitorigoto Season 2 Volume 2), which uses AACS v82.
MakeMKV v1.18.1 fails to decrypt it, and VLC also throws AACS config errors.
I’ve attached the dump created by MakeMKV:
If there’s any additional information or logs needed, I’m happy to provide them!
Thanks in advance — I’m still new to all of this so forgive me if I’m not understanding anything or saying anything wrong.
Dump submission 薬屋のひとりごと2期2巻
Re: Dump submission 薬屋のひとりごと2期2巻
Hi did you send the log to svq@makemkv.com?Drulbob wrote: ↑Fri Jul 25, 2025 6:35 pmHello, I’m having trouble backing up the Japanese Blu-ray disc 薬屋のひとりごと 第2期 2巻 (Kusuriya no Hitorigoto Season 2 Volume 2), which uses AACS v82.
MKB_v82_薬屋のひとりごと 第2期 2_33C6.tgz
Cheers,
CJ
CJ
There is a record for this in the latest KeyDB database. If you haven't already, you can download it and add it to your MakeMKV data directory (where the dumps are) and you should be able to rip it.Drulbob wrote: ↑Fri Jul 25, 2025 6:35 pmHello, I’m having trouble backing up the Japanese Blu-ray disc 薬屋のひとりごと 第2期 2巻 (Kusuriya no Hitorigoto Season 2 Volume 2), which uses AACS v82.
Thanks to both people who replied!
I sent the log to svq@makemkv.com before submitting this post, and then later was able to successfully get it working after downloading the newest keydb.cfg file.
Thank you for the help!
