Is my pioneer BDR-XD05s flashable?
lizardrobot
Re: Is my pioneer BDR-XD05s flashable?
Greetings!
This forum has been extremely helpful in the past. Thank you all for your contributions.
I've discovered from this thread that my BDR-XD05S drive might be flash-able to read UHD discs consistently. I've been able to read some (a German Dune boxset worked fine, for example) but the recent Arrow version of The Andromeda Strain wouldn't read.
One hitch is that I'm Mac-only at home, and I've read that Windows virtual machines won't work for flashing drives. I'm comfortable with the command-line, and have Wine running on my Mac. Is there any hope of flashing my drive without borrowing a Windows PC? I could connect the drive to my Ubuntu home server.
EDIT:
I should post my drive info in case this clarifies things.
I saw instructions in another thread that there are Mac steps for firmware flash, but the Everything Firmware does seem to include Pioneer drives. So I'm confused. Lol. I'll keep reading!
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: redacted
Firmware date: 2014-12-26
Highest AACS version: 81
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
EDIT:
Revision: 3.01
You NEED a Windows PC or a good VM with Windows. Parallels or VMWare should do it. PM sent.lizardrobot wrote: Sun Jul 20, 2025 9:21 pm Greetings!
EDIT:
Revision: 3.01
juggling309
I'd love to flash my drive. Would it be possible ?
Revision: 3.10
Firmware date: 2017-06-22
Best regards.
Revision: 3.10
Best regards.
Yes can be flashed email me that drive info section see below for emailjuggling309 wrote: Wed Jul 23, 2025 3:49 pm Hi,
Revision: 3.10
Best regards.
lizardrobot
Thanks, @Coopervid, I got your package to work fine! I'm sending a grateful donation your way. (I'm going to send something to @Billycar11 as well, because you both do so much for the community.)Coopervid wrote: Mon Jul 21, 2025 10:34 am You NEED a Windows PC or a good VM with Windows. Parallels or VMWare should do it. PM sent.
I want to share the steps I took to flash my drive, since I have resolved not to pay for Parallels any more. I believe these should work for all M-series Mac users.
I downloaded UTM, an open-source application for running virtual machines, for free from their website. You can follow their instructions to obtain and install Windows 11 into a UTM virtual machine. This process worked great for me on my M1 MacBook Pro.
Windows 11 does not require a license code to install into the virtual machine, but the terms and conditions require you to activate a license to continue using Windows. You can use an older Win7+ license should you have one, or purchase a license online from Microsoft. Until Windows 11 is licensed some features will be limited, but you can run applications...like the firmware updater.
Once the Win11 VM was running in UTM, I copied to the firmware updater from my thumb drive, extracted the ZIP archive, and flashed my BDR-XD05s. A test run with a UHD 4K blu-ray worked as I hoped.
Hi! I have a Pioneer BDR-XD05B manufactured in January 2015, and I was wondering if it could be flashed to be UHD capable? Here is the drive information:
OS device name: /dev/rdisk5
Revision: 3.00
Serial number: ------------
Firmware date: 2014-07-30
Firmware version: 3.00/ID34
Thank you!
Revision: 3.00
Thank you!
yes just email me that drive info section see below for emailabheekd wrote: Sun Jul 27, 2025 11:15 pm Hi! I have a Pioneer BDR-XD05B manufactured in January 2015, and I was wondering if it could be flashed to be UHD capable? Here is the drive information:
Revision: 3.00
Thank you!
Hi All,
my XD05 can flash?
OS device name: E:
Revision: 2.01
Serial number:-
Highest AACS version: 77
Drive platform: Pioneer RS8231
Firmware version: ID32
my XD05 can flash?
OS device name: E:
Revision: 2.01
Serial number:-
Email me that drive info see belowkylewong wrote: Sat Aug 02, 2025 7:59 am Hi All,
my XD05 can flash?
OS device name: E:
Revision: 2.01
Serial number:-
Hi!
I have the same drive... Is it still UHD capable?
Revision: 3.01
Serial number:
Highest AACS version: 75
Revision: 3.01
Serial number:
PM sent.aravi wrote: Wed Aug 06, 2025 3:37 pm Hi!
Revision: 3.01
Serial number:
masterdaneth
Hi. I found this thread as well. Have a BD-RW BDR-XD05 looking to flash it to read UHD.
Revision: 3.10
Serial number:
Drive platform: RS8232
Firmware version: 3.10/ID34
Revision: 3.10
Serial number:
Hi Everyone!
I found this in my box of older stuff and didn't know what to do until I stumbled upon this thread. I would appreciate any help you can give me. Thanks!
OS device name: E:
Revision: 3.01
Serial number: ...
Highest AACS version: 76
Cheers!
-HK sends
OS device name: E:
Revision: 3.01
Serial number: ...
Cheers!
-HK sends
PM sent.masterdaneth wrote: Thu Aug 07, 2025 9:06 pm Hi. I found this thread as well. Have a BD-RW BDR-XD05 looking to flash it to read UHD.
Revision: 3.10
Serial number:
PM sent.HK_sends wrote: Fri Aug 08, 2025 12:55 am Hi Everyone!
OS device name: E:
Revision: 3.01
Serial number: ...
Cheers!
-HK sends
