This is my first 4k issue post. I'm having the same issue on all 6 of the movies in the US version of Jurassic Park Ult Ed. MakeMKV is not creating any debug file in users/(username)/.MakeMKV folder where the keydb.cfg file exists. I see a similar failure in the MakeMKV console log for all 6 disks. It starts out saving the file and then crashes at the very last section of Save Selected Titles.
Any ideas how I can correct the errors to save an .mkv properly?
Thanks,
Avaholic
LOG
MakeMKV v1.18.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=A67B88E78837)
Title #01200.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01201.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01120.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01124.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01125.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01122.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01123.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01121.mpls has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00050.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00250.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00251.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00252.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00253.mpls has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00257.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00274.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00258.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00259.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00260.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00261.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00262.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00263.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00264.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00265.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00313.mpls was added as title #1
Title #00314.mpls has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00315.mpls was added as title #2
Title #00316.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00317.mpls was added as title #3
File 00318.mpls was added as title #4
Title #00319.mpls has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00320.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50057.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50058.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50199.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50200.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00300.m2ts was added as title #5
Title #50277.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50278.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50283.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50284.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00301.m2ts was added as title #6
File 00302.m2ts was added as title #7
File 00303.m2ts was added as title #8
File 00305.m2ts was added as title #9
File 00306.m2ts was added as title #10
File 00307.m2ts was added as title #11
Title #00308.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00309.m2ts was added as title #12
File 00310.m2ts was added as title #13
File 00311.m2ts was added as title #14
Title #00312.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00321.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00322.m2ts was added as title #15
File 50285.m2ts was added as title #16
Saving 1 titles into directory F:/Video/Jurassic Park
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '24844763136'
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom0' at offset '24844763136'
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '24844763136'
Failed to save title 0 to file F:/Video/Jurassic Park/Jurassic Park_t00.mkv
0 titles saved, 1 failed
Jurassic Park Ultimate Ed issues with all disks.
avaholic
Re: Jurassic Park Ultimate Ed issues with all disks.
Looks like an external drive that decided to go home and take its ball. If it's usb check that it's getting enough power.
avaholic
It is an external 4K Bluray drive. https://www.amazon.com/dp/B0D5CFY8RW
I was able to make mkvs of several other 4k disks including the Brand new Criterion Collection Brazil disks. I don't understand why these 6 won't complete successfully.
Here's the drive info. Is there anything wrong with this drive?:
F:\FindVUK>findvuk.exe showdrivedetails
18:25:37 - ----------- FindVUK 1.82 -----------
To close FindVUK simply press the ESC key
18:25:37 - ShowDriveDetails for Drive >E:\<
18:25:37 - Vendor >HL-DT-ST< ProductId >BD-RE BU40N < ProductRevision >FR07< ScsiDeviceType >CD/DVD-ROM device< ConnectedTo >USB< Bus
--COMMON--------------------------------------------------------------------------------
18:25:37 - Drive Vendor : HL-DT-ST
18:25:37 - Drive Model : BD-RE BU40N
18:25:37 - Drive Revision : FR07
18:25:37 - Drive VendorSpec : JM02202806HS007003
18:25:37 - FirmwareCreationDate : 211801221536
18:25:37 - Drive Interface : Serial ATAPI
18:25:37 - Drive Type : BLURAY/DVD/CD-WRITER
18:25:37 - LoadingMechanism : Tray
--DRIVE FEATURES------------------------------------------------------------------------
18:25:37 - Drive Features :
18:25:37 - Profile List, Core, Morphing, Removeable Medium, Write Protect, Random Readable,
18:25:37 - Multi-Read, CD Read, DVD Read, Random Writeable, Incremental Streaming Writeable,
18:25:37 - Formattable, Hardware Defect Management, Restricted Overwrite, CD-RW CAV Write,
18:25:37 - DVD+RW, DVD+R, Rigid Restricted Overwrite, CD Track at Once, CD Mastering,
18:25:37 - DVD-R/-RW Write, Layer Jump Recording, CD-RW Media Write Support, BD-R POW,
18:25:37 - DVD+R Dual Layer, BD Read Feature, BD Write Feature, Hybrid Disc, Power Management,
18:25:37 - SMART, CD Audio External Play, Microcode Update, Timeout, DVD-CSS, Real Time Streaming,
18:25:37 - Drive Serial Number, Media Serial Number, DCBs, DVD CPRM, Firmware Information,
18:25:37 - AACS, AACS2
--DRIVE PROFILES------------------------------------------------------------------------
18:25:37 - Drive Profiles :
18:25:37 - BD-RE, BD-R RRM, BD-R SRM, BD-ROM, DVD+R Dual Layer, DVD+R, DVD+RW, DVD-R Dual Layer Jump Recording,
18:25:37 - DVD-R Dual Layer Sequential Recording, DVD-RW Sequential Recording, DVD-RW Restricted Overwrite,
18:25:37 - DVD-RAM, DVD-R Sequential Recording, DVD-ROM, CD-RW, CD-R, CD-ROM, Removeable disk
--AACS----------------------------------------------------------------------------------
18:25:37 - FeatureDescriptor : 01 0D 09 04 1F 01 02 01
18:25:37 - AacsVersion : 1
18:25:38 - AacsActive : 1
18:25:38 - BindingNonceGenSupp : 1
18:25:38 - BindingNonceBlockCnt : 1
18:25:38 - BusEncryptionSupport : 1
18:25:38 - ReadDriveCertificate : 1
18:25:38 - AgidCount : 2
18:25:38 - Drive is detected as 'REAL BLURAY' drive
18:25:38 - Drive is already in the KnownDrivesList
Post the MakeMKV drive info and libredrive info sections.avaholic wrote: Fri Jul 25, 2025 11:34 pm It is an external 4K Bluray drive. https://www.amazon.com/dp/B0D5CFY8RW
avaholic
As requested:
OS device name: E:
Product: BD-RE BU40N
Revision: FR07
Serial number: 806HS007003
Firmware date: 2118-01-22 15:36
Bus encryption flags: 1F
Highest AACS version: 77
Firmware version: 0.FR07J
But I figured out the issue... Based on an Amazon review that I didn't even notice, I simply added an external power source to the drive's USB-Micros B connector and now 3 of the 6 disks have completed without error.
Nevertheless, is my drive configured properly?
OS device name: E:
Revision: FR07
Yes. And that is why I said to check the power.
