Spider-Man (2002) Backup Fails
dolphin
Post by dolphin »
Backing up Spider-Man (2002) always fails despite trying different computers (all Macs), drives, and discs. If I log debug messages, I get one, solitary error.
With MakeMKV v1.18.1 [darwin(arm64-release)]:
Backing up disc into folder "/[...]/DVD/backup/Spider-Man (2002).iso"
DEBUG: Code 0 at 9eS$innFdFOuvjlCt~9d:121266097
Backup failed
This appears to be a hash of a file and line number in the code.
The exact same error is produced when trying to back up the bonus disc. Is there something different I can try? Or could there be a bug in MakeMKV?
Disc Information
Label: DVD_VIDEO
Timestamp: 2002-08-14 15:57:15
Protection: CSS/CPPM
Data capacity: 7.36 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Re: Spider-Man (2002) Backup Fails
What happens if you try an older version of MakeMKV? https://makemkv.com/download/old/
According to the revision history, the DVD engine was rewritten in 1.17.0. Perhaps give version 1.16.7 a try.
Version 1.18.0 fixed a crash that was introduced by changes in MacOS 15.4. So if your Mac is up-to-date on the OS, the older versions might not work. Hopefully you have a Mac with an older version of MacOS on it.
dolphin
Post by dolphin »
dcoke22 wrote: Sun Jul 20, 2025 11:30 pm What happens if you try an older version of MakeMKV? https://makemkv.com/download/old/
I wondered the same thing, but maybe didn't try the right combination.
I tried v1.18.1 on a new mini M4 Pro, v1.18.1 on a 2011 iMac running High Sierra (10.13.6) and v1.10.5 on a 2008 MacBook Pro running Snow Leopard (10.6.8). The latter just complained the program was "too old" (and unregistered). I think I travelled too far back in time!
I'll give 1.16.7 a shot on the iMac. Appreciate the advice!
dolphin
Post by dolphin »
v1.16.7 doesn't work, either.
I installed v1.16.7, set my system clock back to June 2022, and launched MakeMKV. The option to "backup" was grayed out in both the toolbar and menu. I tried the CLI and got the following:
MSG:5072,131072,1,"Backing up disc into folder \"file:[...]/Spider-Man.iso\"","Backing up disc into folder \"%1\"","file:[...]/Spider-Man.iso"
MSG:1003,16777248,3,"DEBUG: Code 0 at ]e:KbvkWM0NJ2xUsJvr:213141139","DEBUG: Code %1 at %2:%3","0","]e:KbvkWM0NJ2xUsJvr","213141139"
MSG:1003,16777248,3,"DEBUG: Code 0 at JMLyq5mCfgiW96\\E>f~@:213133457","DEBUG: Code %1 at %2:%3","0","JMLyq5mCfgiW96\\E>f~@","213133457"
MSG:1003,32,3,"DEBUG: Code 233 at PGeQoNrevjfHpAeWV5XwbOa5:0","DEBUG: Code %1 at %2:%3","233","PGeQoNrevjfHpAeWV5XwbOa5","0"
MSG:5069,128,0,"Backup failed","Backup failed"
MSG:5080,516,0,"Backup failed.","Backup failed."
I could extract separate titles, but I've been able to do that with all the combinations I've tried. I simply cannot back up the disc. In the case of 1.16.7, it took ~15 minutes to scan the main feature. But at least it gave me a warning:
Complex multiplex encountered - 40 cells and 14511 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
[This was off by a tad. It was more like 2.8 million VOBUs, but that may be the "complex multiplex" effect. v1.18.1 is much faster.]
I've tried other things, like creating a DVD master ISO from the disc and trying to back that up. Same problem.
There appears to be a discrepancy (bug) between how title-sets are scanned when extracting individual titles and how they are scanned when backing up a disc.
Gory details on the v1.18.1 CLI attempt follows...
makemkvcon backup --decrypt --cache=128 --noscan -r --progress=-same disc:1 [path]/sm.iso
It behaved (expectedly) just like the GUI. Specifically, it starts scanning the contents, gets through the MENU (apparently) and then croaks before finishing the scan (possibly when starting to scan the first title). Here's the terminal output (with personal file paths redacted):
% makemkvcon backup --decrypt --cache=128 --noscan -r --progress=-same disc:1 [path]/sm.iso
MSG:1005,0,1,"MakeMKV v1.18.1 darwin(arm64-release) started","%1 started","MakeMKV v1.18.1 darwin(arm64-release)"
MSG:1004,131072,1,"Debug logging enabled, log will be saved as file:[...]/MakeMKV_log.txt","Debug logging enabled, log will be saved as %1","file:[...]/MakeMKV_log.txt"
PRGT:5018,0,"Scanning CD-ROM devices"
PRGC:5018,0,"Scanning CD-ROM devices"
PRGV:0,0,65536
PRGV:0,0,65536
MSG:2010,16777216,1,"Optical drive \"DVD+R-DL HL-DT-ST DVDRW  GX50N RR06 KX1E8U53308d\" opened in OS access mode.","Optical drive \"%1\" opened in OS access mode.","DVD+R-DL HL-DT-ST DVDRW  GX50N RR06 KX1E8U53308d"
MSG:2010,0,1,"Optical drive \"BD-RE PIONEER BD-RW   BDR-XD08 1.02 DIDL013383UCd\" opened in OS access mode.","Optical drive \"%1\" opened in OS access mode.","BD-RE PIONEER BD-RW   BDR-XD08 1.02 DIDL013383UCd"
PRGV:65536,0,65536
PRGV:65536,65536,65536
DRV:0,0,999,0,"DVD+R-DL HL-DT-ST DVDRW  GX50N RR06 KX1E8U53308","",""
DRV:1,0,999,0,"BD-RE PIONEER BD-RW   BDR-XD08 1.02 DIDL013383UC","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
PRGV:0,65536,65536
PRGV:0,0,65536
MSG:5072,131072,1,"Backing up disc into folder \"file:[path]/sm.iso\"","Backing up disc into folder \"%1\"","file:[path]/sm.iso"
PRGT:5047,0,"Copying all files"
PRGC:3102,0,"Processing title sets"
PRGV:0,0,65536
PRGV:0,0,65536
PRGV:5041,0,65536
PRGV:10082,0,65536
PRGV:15123,0,65536
PRGV:20164,0,65536
PRGV:25206,0,65536
PRGV:30247,0,65536
PRGV:35288,0,65536
PRGV:40329,0,65536
PRGV:45371,0,65536
PRGV:50412,0,65536
PRGV:55453,0,65536
PRGV:60494,0,65536
PRGC:3120,1,"Scanning contents"
PRGV:0,0,65536
PRGV:655,0,65536
PRGC:5046,0,"Copying file"
PRGV:0,0,65536
MSG:1003,32,3,"DEBUG: Code 0 at 9eS$innFdFOuvjlCt~9d:121266097","DEBUG: Code %1 at %2:%3","0","9eS$innFdFOuvjlCt~9d","121266097"
There are 29 title sets (based on the successful scan when I extract just the main feature), but it can't make it past the menu.
In case someone asks, "What about the debug log?" Well, here it is:
Debug log started at Fri Jul 25 00:23:47 2025 , written by MakeMKV v1.18.1 darwin(arm64-release)
001005:0000 MakeMKV v1.18.1 darwin(arm64-release) started
001004:0000 Debug logging enabled, log will be saved as file:[...]/MakeMKV_log.txt
Using 131328KB for read cache.
Network access is ENABLED, CURL version 8.7.1/(SecureTransport) LibreSSL/3.3.6/1.64.0 (x86_64-apple-darwin24.0) , proxy server not set.
002010:0000 Optical drive "DVD+R-DL HL-DT-ST DVDRW GX50N RR06 KX1E8U53308d" opened in OS access mode.
002010:0000 Optical drive "BD-RE PIONEER BD-RW BDR-XD08 1.02 DIDL013383UCd" opened in OS access mode.
No SDF v098: HL-DT-ST_DVDRW__GX50N_RR06_201407211334_KX1E8U53308
SDF id v098: HL-DT-ST_DVDRW__GX50N_RR06_201407211334_KX1E8U53308
No SDF v098: PIONEER_BD-RW___BDR-XD08_1.02_DIDL013383UC
SDF id v098: PIONEER_BD-RW___BDR-XD08_1.02_DIDL013383UC
DEBUG: Code 0 at T{S-z0r|;^LW"3A@|:29396253
DEBUG: Code 0 at SkVY[^[Mjt<aPqh$:213136746
005072:0000 Backing up disc into folder "file:[path]/sm.iso"
Launching /Applications/MakeMKV.app/Contents/MacOS/mmgplsrv
DEBUG: Code 0 at U]c9%Lad~W!r'v"`!a0c:29396460
001003:0020 DEBUG: Code 0 at 9eS$innFdFOuvjlCt~9d:121266097
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Fri Jul 25 00:25:04 2025
bufulo
Post by bufulo »
It must be a bug. I see the exact same failure with multiple discs on different computers, different drives, and different versions of MakeMKV. The digits after the ":" are identical "121266097".
This is what I get for Spider-Man:
DEBUG: Code 0 at r79-F\`Qopn&7y,}?R%):121266097
Backup failed
Another example is A River Runs Through It which yields the following (notice the 121266097 again):
Backing up disc into folder "F:/A River Runs Through It (1992)/A River Runs Through It (1992).iso"
DEBUG: Code 321 at sC}~<8WP`ShO+AQh]WP:121263222
DEBUG: Code 0 at B`ut4y]!X\p5gw'4V:jX:121266097
Backup failed
bufulo
Post by bufulo »
Two more examples:
Mr. Woodcock (2007) yields DEBUG: Code 0 at B`ut4y]!X\p5gw'4V:jX:121266097.
Captain America - The First Avenger (2011) yields DEBUG: Code 0 at #5Q.cQ`>r,#pAMVd=%ky:121266097.
So maybe the 121266097 really doesn't mean anything but it sure would be nice to figure out why these 5 DVDs fail to Backup.
dolphin
Post by dolphin »
Captain America: The First Avenger also fails for me, as does Footloose (1984 and 2011), and a Monsters, Inc. (2001) bonus disc.
bufulo
Post by bufulo »
Same digits (121266097) in the debug stuff someplace for those as well?
I should also note that I get the same failure on multiple copies of the same movie (i.e., I tried another DVD of the same move and got the same error). So it certainly seems to be a problem with MakeMKV not being able to deal with the encryption or something with these DVD titles!
gkar_of_narn
Post by gkar_of_narn »
I decided to try and rip Spider-Man 2002, main disc not the bonus disk.
Windows XP 32 system
Makemkv 1.18.1 in auto mode
De-selected everything but the one big file and 5.1 audio.Went without a hitch. No problems.
dolphin
Post by dolphin »
gkar_of_narn wrote: Fri Sep 26, 2025 1:48 am Hi,
Extracting individual titles is not the problem. MakeMKV fails on these when doing a full disc backup. Please try that and report how it goes.
gkar_of_narn
Didn't know you can do a full disk backup. How do you do that?
Blyth
Post by Blyth »
gkar_of_narn wrote: Fri Sep 26, 2025 3:49 pm Didn't know you can do a full disk backup. How do you do that?
At the top row there is a backup button click on it.
gkar_of_narn
Thanks, I figured it out. It looks like it fails ripping the menu. I tried ripping it with Dvdfabdecrypter and shrinking it and sticking it on dvdrw. It still failed mkv full dvd, so i tried dvdshrink and sticking on a dvdrw. mkv full dvd still failed. so i did a movie only rip with dvdshrink and stuck it on a dvdrw. mkv full dvd was successful.
bufulo
Post by bufulo »
So it looks like you've confirmed this is a problem with MakeMKV Backup, which is what we're claiming. I don't think you've shown it has anything to do with disc menus but that's irrelevant to the end user anyway. The problem is MakeMKV Backup fails with some (too many) DVD titles. I have at least 7 DVDs now that MakeMKV cannot Backup due to what appears to be the same bug although one also has RipGuard involved.
I'm seeing LOTS of posts here with Backup problems...
Hopefully this gets fixed soon and even better if your claim that it has something to do with menus helps solve the problem.
bufulo
Post by bufulo »
Since this thread, I've had at least another half a dozen DVDs fail to backup. I think all of them made use of RipGuard (at least according to MakeMKV they did). It seems pretty obvious that there is something wrong with the Backup code in MakeMKV. Either that or RipGuard is simply winning this battle.
Are there other utilities and/or drive that work more reliably for DVDs using RipGuard?
